Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Re-allocated Sector Count: 10 and counting
Hi.
I bought an Intel X25-M 160GB (gen. 2) a few months ago, and the SMART attributes from Intel's SSD Toolbox says that my Re-allocated Sector Count is 10.
This number has slowly been increasing since I got the drive.
Another weird thing is that the drive emits low electronic noise when it's under load. I thought SSDs should be totally silent?
Maybe these two problems are symptoms of a defective drive?
The drive is running on an ASUS P6T V2 motherboard (Intel X58 chipset).
Tags (1)
Community Manager
Your drive should not be making a noise. Are you sure it is coming from the drive? Sometimes its hard to track noise especially if it is high frequency. It might be worth giving this a shot to try and isolate the problem:
Go to "Start," then "Control Panel," and then click on the "Hardware & Sound" category. Then click on the "Sound" category, and then click on the "Recording" tab. Highlight the microphone and go to Properties. Select the "Listen" tab and "Mute" the mic as well as put a check mark where it says "Listen to this device."
Regarding the Re-allocated Sector Count I have used an X25-M 160GB from the day it came out and I have a count of 3 with 2.46TB of writes. I'd keep an eye on it and seek advice from Intel support if it continues to rise.
