Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Reason the SSD tool was pulled
FYI. Just to keep the masses informed. See link http://www.intel.com/support/ssdc/hpssd/sb/CS-031020.htm
And this link http://www.intel.com/support/ssdc/hpssd/sb/CS-031073.htm
"Microsoft* alerted Intel to an issue with the Intel® SSD Optimizer tool and Intel is working on a fix to the issue. After the SSD Optimizer is run, the SSD Optimizer renders all previously set Windows* system restore points unusable. However, user data is not affected. The SSD Optimizer tool is part of the Intel® SSD Toolbox (ver 1.1).
This applies only to users who meet all four criteria below:
  • Use Windows*7 or Vista and
  • Use the System Protection feature which sets system restore points (enabled by default in Windows*7 and Vista*) and
  • Have installed 02HA firmware and
  • Have used Intel SSD Optimizer (which was available from intel.com from 10/26 to 11/4).
A workaround for this issue and additional http://support.intel.com/support/ssdc/hpssd/sb/CS-031073.htm details are available here. Intel will give regular updates on this issue. Please note this issue is not related to the Intel SSD firmware update process covered in a separate announcement (Intel® Solid-State Drive Firmware Update)."
NOTE for Moderators: It would be nice to post this where the other messages are, or better yet create a sticky if that is possible. Communication is essential to good customer service.
Tags (2)
Community Manager
...or we, the masses, could simply click on the announcement banner at the top of the message boards
Community Manager
Oops! Now i feel like an idiot. Didn't see that. I don't care for the message thing at the top because you have to remember to look at it or notice that the number has changed. I like the sticky think better. Maybe the forum software can't create stickies.
Community Manager
BANNER????!!!!!!!what banner i dont see no banner
Community Manager
