Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Restoring 160GB G2 drive to factory state - Full, quick format or HDDErase 3.3?
I'm intending on reducing my SSD size to 144GB to gain claimed 2.8X endurance improvement by having 10% more spare space.
I need to choose the solution to erase the drive before repartitioning.
Which is the best:
  1. full format (from other OS booted drive)
  2. quick format
  3. Using HDDErase 3.3. tool
Tags (1)
Community Manager
The best method of restoring your SSD to the factory default state is to use the ATA "Secure Erase" command. Unfortunately, it's not simple to figure out what commands are actually being done by Windows or various drive tools.
Regarding the potential 2.8X endurance increase, I recommend you read a similar thread:
/thread/11591?tstart=30 http://communities.intel.com/thread/11591?tstart=30
Hope that helps.
Community Manager
From what I've read there, there is no real use in this method?
Community Manager
To summarize the other thread:
The endurance benefit from reducing capacity is a function of the write amplication that the drive is seeing. For a normal client usage model, the write amplication is already quite low, so there will be smaller endurance increase. But the benfits for an enterprise server usage model can be significant.
Community Manager
Exactly as I got it. Thanks for assistance.
