Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Rollback SSD to earlier Firmware?
Hi all. I have an Intel X25-M 160GB SSD. I recently updated the SSD using the Intel Solid-State Drive Toolbox v3.1.2 and I am having serious problems with my SSD using this new firmware.
Where can I go to obtain earlier versions of firmware for my X25-M 160GB SSD at? I'd like to rollback the firmware on my SSD to an earlier version. Is this possible?
Thanks!
Community Manager
Anyone care to take a shot at this?
I really need to install the previous firmware that was on my SSD. Where can I go to get older firmware that Intel had released?
JAMES_J_Intel
Did you recently download the Toolbox which updated yur SSD? The firmware for that drive has not been updated in over a year. I am not aware of any issues with the 02M3 firmware. What are the serious problems you are experiencing?
Jim
Community Manager
Hi Jim, thanks for your response!
Here is what happened:
I purchased a brand new Intel X25-M 160GB SSD (SSDSA2MH160G2R5) a couple of years ago for an X58 build. During that time, the SSD sat in its packaging, sealed. Well, I finally completed that build about three months ago (better late than never!), and used the SSD as my boot drive. The system performed flawlessly.
About a month ago, I downloaded the Intel SSD Toolbox for the first time and discovered that an update for the firmware on my SSD was available. I went ahead and updated the firmware and since then, my system has been acting in the following manner:
1) If I have the screen saver set to turn on after a set period of time, the PC becomes unresponsive when I try to resume work. I can click icons and move the mouse around, but no windows will open. In order to get back to work, I have to perform a hard reset on the system.
2) If I have the monitor set to turn off after a set period of time, the PC becomes unresponsive when I try to resume work. I can click icons and move the mouse around, but again, no windows will open (a hard reset is needed).
3) If both the screen saver and monitor power off options are disabled, and the computer sits idling for a length of time, the PC is unresponsive when I try to resume work, even though I can click on icons and move the mouse around. Again, a hard reset is needed.
I have tried the following to fix this: making sure my BIOS is up to date, the firmware on the SSD is current, and any power options that would put the PC (or its components, such as HDDs) to sleep, hibernate, or idle itself down to save power have been disabled. I have also verified that ACHI mode is enabled for all devices.
I have also donwloaded and installed the latest Intel RST software. None of the things I mentioned have fixed the problems I am experiencing. I am at a loss to explain why a system that once performed flawlessy is now locking my PC up after upgrading the firmware on the SSD.
The SSD firmware version that is currently on the SSD is 2CV102M3.
I am convinced that if I were able to roll-back the firmware or install an older version of the firmware on the SSD that the problems I am having would be resolved.
Any help you could offer would be greatly appreciated. I have taken a photo of the retail box with the information on the side panel if this will help determine what firmware version originally came with the SSD.
http://img.photobucket.com/albums/v302/garetjax27/Mis/SSD_Info-1.png http://img.photobucket.com/albums/v302/garetjax27/Mis/SSD_Info-1.png
Thanks!
Community Manager
Jim,
Any chance of having you weigh in? I'd rather not have to RMA this SSD (covered under warranty until March 2013), but at this point, I don't know what else I can do to fix this issue.
Thanks!
Community Manager
I've never heard of anyone being able to (or needing to) change to an earlier firmware version on an Intel SSD. The methods used by Intel for firmware updates do not use separate firmware files and update program, so I really doubt that you can change to the earlier firmware.
Your problem may be related to a power issue with the SSD, and Windows. Do you know what Windows Power Plan you are using? The main thing to try is in the Advanced power plan settings, is setting "Shut off HDD" to Never. Let us know if that works for you.
Community Manager
Thanks for the response, parsec.
I have verified that my power options are set to "Performance" and that my HDDs are set to Never shut down. Unfortunately, I am still having the same problems as described above.
At this point, I'm starting to lean towards sending the warranty the SSD back to Intel.
Community Manager
The X25-M G2 Intel SSDs have two firmware versions, the original is 2CV102HD, and the update as you know is 2CV102M3. Since the firmware you are interested in was not an update, it was never supplied in any update tool or as an individual file. So the chances of finding it, or even a way to change to it are zero IMO.
Your X58 board uses the Intel ICH10R SATA II chipset, which was a very well respected product, I've used several boards that had it and never had problems with it. As long as you are certain you are in AHCI mode now, you could try the following:
Check or replace the data cable, with replacing it the best option. Also check the power connection, as in removing the connector from the SSD and reinserting it.
The SSD Toolbox has two Diagnostic tests, you might as well run them and see if any problems have occurred.
A much more work intensive option it to secure erase the SSD with the Toolbox. That will COMPLETELY ERASE the contents of the drive, NEVER to be retrieved again!! You would need to back up the SSD completely, and restore it after the secure erase.
Ask yourself, are you absolutely certain that your issues started after the firmware update, and there was nothing else you did to the PC that might have caused it? An easy thing to overlook, I've done it many times.
Personally, I've used and still use several of the 80GB version of your SSD, with the new firmware, which has been available for going on two years, and they work fine. Your SSD may have other problems, and you can contact Intel support directly via the Support link at the bottom of this page.
Community Manager
Hi Parsec.
Based on your last post, I have performed the following:
1. Replaced the SSD SATA data cable with a known-to-be-good cable
2. Ensured that the power connection is good and providing sufficient power to the SSD
3. Ran both diagnostic tests on the SSD using the Intel Toolbox
Unfortunately, I am still experiecing the same issues that I had before.
I am absolutely certain that these problems surface when I updated the firmware on the SSD. Fearing that it may have been a Microsoft update, I have restored the PC back to the original way it was prior to when I updated the firmware on the SSD to no avail.
The only remaining option that I have now is to try wiping the SSD and re-imaging a backup onto it. I'll report back with the results.
Thanks again!
KenF_Intel
Hi Garetjax,
As mentioned earlier, we don't have a way to rollback the firmware.
Any luck with the new OS installation? Did that change your systems behavior?
