cancel
Showing results for
Search instead for
Did you mean:
Running secure erase command on DC P3700 from a laptop
PLync1
New Contributor
Hi, is there an eSATA or USB cable that allows one to connect to a DC P3700 so one can run the secure erase command?
1 REPLY 1
ASouz7
Valued Contributor
pl,
There could be adapters on the marked and for that you need to check since Intel does not provide these cables.
