Community
cancel
Showing results for
Search instead for
Did you mean:
PLync1
Running secure erase command on DC P3700 from a laptop
Hi, is there an eSATA or USB cable that allows one to connect to a DC P3700 so one can run the secure erase command?
ASouz7
pl,
There could be adapters on the marked and for that you need to check since Intel does not provide these cables.
