Community
cancel
Showing results for
Search instead for
Did you mean:
FGree
S3500 SSDSC1NB240G401 Firmware update issue
Jump to solution
Hi. I'm trying to update the firmware on a S3500. I have two different cables that connect to it. https://www.amazon.com/gp/product/B002RCQ6U2/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1 This and https://www.amazon.com/gp/product/B00NING8K2/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1 this.
For the USB adapter, my computer will recognize the drive but Intel SSD Toolbox won't.
For the Sata to Micro Sata cable, this computer doesn't pick it up at all. It's running windows 7 with C220 Chipset Family SATA AHCI Controller.
I've tested the Sata-Micro Sata cable on an older PC running XP and while the computer and intel toolbox will recognize the drive, the intel program gives connection issue error when trying to update the firmware.
Any thoughts on this or maybe there is a better cable out there? Thanks for your time and help.
Frank
Community Manager
Hello Frankgreen,
We understand you would like to update the firmware in your SSD but it keeps failing.
First of all, could you let us know what is the firmware version at the moment? (You can check that using the Intel® Solid-State Drive Toolbox).
The best way to try to run the firmware update is using the https://downloadcenter.intel.com/download/26491/Intel-SSD-Firmware-Update-Tool firmware update tool, you can download it and use the ISO file to boot the system from and run the update that way.
About the cables you are using, for you to know, the USB adapter is not going to work using the Intel® Solid-State Drive Toolbox since the program does not recognize drives not attached to the SATA port directly.
Please let us know if you can update the firmware using the firmware update tool.
Nestor C
Community Manager
Hello Frankgreen,
Nestor C
FGree
Hi Nestor,
The drives have the firmware D2010355.
I made an ISO and it seems to work fine on my windows 7 machine but I run into this error on the XP one.
FGree
Also, while the update tool loads on my windows 7 box, it doesn't recognize the drive with either cable. I feel like I'm in the twilight zone.
Community Manager
Hi Frankgreen,
On this case, since the firmware update tool does boot in your Windows* 7 system, but does not see the drive, we would like to ask you:
-What are your system's specs
-Did you try with the SSD plugged in the USB or SATA cable (Or both ways)
-Can you try the update in a laptop computer?
For the Windows* XP system, about the firmware error, you can try to setup the BIOS of the system in legacy mode and try again.
Please let us know, we'll be waiting for you.
Nestor C
FGree
Hi Nestor,
I've tried a few more computers and finally found a combo that worked. Thanks for taking your time to help.
Frank
Community Manager
Hi Frankgreen,
Thanks for confirming that you successfully upgraded the SSD.
Have a nice weekend.
Nestor C
