Community
cancel
Showing results for
Search instead for
Did you mean:
JHeds1
S3500 Series 800GB w 8MB bug!
Got a brand new SSD DC S3500 Series 800 GB disk for my Macbook Pro in february 2014.
Last night it kicked the bucket after a forced power off - from 800 GB to 8,4 MB in 1 secs.
Now, since this bug has been around since 2011, has anyone found a way to recover any data from a drive that's been hit?
RYang19
I am encountering this issue as well.
Can you recall what state or what operation your notebook was performing before going to the 8MB state?
A secure erase can revive the drive, but data will be erased.
JHeds1
My mac was starting up from sleep mode but before I was able to login I got the spinning beach ball for some reason. My patience ran out after about 5 minutes, I forced a power-off by pressing the pwr button for a couple of secs. At the next startup I got a folder icon with a flashing question mark...then it was all over.
Jose_H_Intel1
You may take the Intel® SSD to a data recovery service; if you prefer, go with an Intel® Partner such as the ones listed below, this way you will make sure the warranty will not be affected.
For warranty replacements please contact your nearest http://www.intel.com/p/en_US/support/contactsupport Intel® support team.
I am truly sorry for the inconvenience.
NOTE: These links are being offered for your convenience and should not be viewed as an endorsement by Intel of the content, products, or services offered there.
JHeds1
Thanks for the links, Joe_Intel.
My main concern now is trust! My impression was that this issue was solved? I mean, It 's been two and a half yrs since it was acknowledged by Intel (on the 320 series).
fxor
/message/234233# 234233 S3500 Series 800GB w 8MB bug is back!
Yesterday I tried to update firmware on my DC S3500 800Gb from D2010350 to D2010370 update failed and drive is sowing 8MB.
Firmware update fails after 10% with bookable http://downloadcenter.intel.com/confirm.aspx?httpDown=http://downloadmirror.intel.com/18363/eng/issd... issdfut_2.0.13.iso.AND
Secure erase don't work with SSD toolbox and with "SSDProAdminTool_1.1.0_x64.exe" what should I do?
Please help.
fxor
Please help.
Jose_H_Intel1
Please try the http://www.thomas-krenn.com/en/wiki/SSD_Secure_Erase Secure Erase under Linux*. There are some utilities available online that will allow you to create a bootable Linux* drive, such as this one: http://www.pendrivelinux.com/yumi-multiboot-usb-creator/ http://www.pendrivelinux.com/yumi-multiboot-usb-creator/
fxor
Thank for the information .
But setting security set password command fails : Input/Output error
Any ideas?
Jose_H_Intel1
So, I assume you have not yet been able to secure erase it?
Did you try setting up the Hard Drive password in the BIOS?
fxor
I am unable to secure erase it.
Can't set the password
Jose_H_Intel1
If you are not able to remove/reset the password or secure erase the drive I believe the best option will be to contact your nearest http://www.intel.com/p/en_US/support/contactsupport Intel support team for you to request a warranty replacement.
fxor
I have sent SSD for warranty replacement. Warranty dept couldn't help as my SSD says Engineering Sample.
Please help
Jose_H_Intel1
In this case I suggest you return it to the seller.
I am sorry for the inconvenience.
fxor
Seller is not helping since SSD was working and current release of firmware made it unusable.
Can you please find an alternate procedure to re-FLASH old working firmware from engineering development dept.
Jose_H_Intel1
Intel engineering sample products are not meant to be sold nor made available to the general public by Intel. They are generally only loaned by Intel to Intel's Original Equipment Manufacturers (OEMs), Original Device Manufacturers (ODMs), and Independent Software Vendors (ISVs) for pre-production test and evaluation work under specific contractual terms and conditions that assure the protection of Intel's assets and confidential information. Therefore, engineering sample products are not covered under Intel warranty and are generally not supported by Intel.
Our best suggestion for you is to file a claim with the respective consumer protection agency depending on the country where the product was purchased. For instance: the http://www.bbb.org/ Better Business Bureau in North America, the online store, or the auction site policies if it was purchased that way.
fxor
My working SSD is damaged by Intel's official firmware release hence I am expecting support. I don't mind getting my SSD replaced by another engineering sample or whatever. I need working SSD as before Intel's official firmware update.
Jose_H_Intel1
Please allow us to check for options in this case.
fxor
Sure.
BTW Intel already have my this SSD for Repair/ Replacement/ Analysis for a month now.
fxor
I am waiting for more than 2 weeks for a reply
KenF_Intel
Hi Nr3,
We have made several attempts to install new firmware on the drive you sent us, but it is simply not possible. We have shipped your product back to you. It should arrive on Monday, Oct. 13.
Your engineering sample had pre-production firmware that was never intended to be updated. That is why the firmware update you tried failed and left the drive unusable.
It is truly unfortunate that you are in this position.
Hopefully you were informed that you were buying an engineering sample when you purchased the product. If that is not the case then we suggest that you take whatever action you feel appropriate with your place of purchase.
