cancel
Showing results for
Search instead for
Did you mean:
S3610 smart function unavailable - Can't update firmware
echen53
New Contributor
My other S3610 1.6tb works, but my 1.2tb seems to have smart function disabled on it. Using the diagnostic toolbox, it says I need to contact intel to update the firmware. Instead of contacting intel, I used the firmware update tool and it said that it was updated, but the smart function is still unavailable.
7 REPLIES 7
Esteemed Contributor III
Hi Cheneric,
Since this was purchased with a "locked" firmware (Second handed), it is most likely some sort of engineering sample, therefore, it comes with very limited options.On this kind of drives, there is no way to update the firmware and its use is more for testing purposes.Regards,Nestor C
I see, that's too bad. Thanks for letting me know!
Hi Cheneric,
You are welcome. At least we found the root cause of this situation.Have a nice day.Regards,Nestor C
