Community
cancel
Showing results for
Search instead for
Did you mean:
echen53
S3610 smart function unavailable - Can't update firmware
My other S3610 1.6tb works, but my 1.2tb seems to have smart function disabled on it. Using the diagnostic toolbox, it says I need to contact intel to update the firmware. Instead of contacting intel, I used the firmware update tool and it said that it was updated, but the smart function is still unavailable.
Community Manager
Hello Cheneric,
We understand you would like to know why the SMART functionality is not working or disabled and at the same time, to check if the firmware is fine on it.
First of all, could you please confirm if the firmware version on the SSD is: G2010160?
Now, about the SMART function, can you please download https://downloadcenter.intel.com/download/26575/Intel-SSD-Data-Center-Tool this tool and run the SMART command: isdct.exe show –smart and please let us know what you see.
Also,
-Do you have both SSDs connected to the same computer?
-What is the operating system you have installed?
-Could you share brand and model of the system or the specs?
We'll be waiting for your response.
Nestor C
echen53
Firmware is G2010150.
The SSD Toolbox says I have pre-production firmware.
Same computer.
Community Manager
Hi Cheneric,
Thanks for confirming the information.
-We'd like to know where did you purchase the SSD?
-Also, could you try the https://downloadcenter.intel.com/download/26491/Intel-SSD-Firmware-Update-Tool following link to try to update the firmware on it?
-Could you please export the *.csv file from Intel® Solid-State Drive Toolbox and attach it to the thread?
-Is the other drive you have presenting the same message under Intel® Solid-State Drive Toolbox? (Pre-production firmware)
Nestor C
echen53
I purchased it from ebay.
The seller just told me that it has locked firmware. Is there nothing I can do to enable the smart function?
Community Manager
Hi Cheneric,
Since this was purchased with a "locked" firmware (Second handed), it is most likely some sort of engineering sample, therefore, it comes with very limited options.
On this kind of drives, there is no way to update the firmware and its use is more for testing purposes.
Nestor C
echen53
I see, that's too bad. Thanks for letting me know!
Community Manager
Hi Cheneric,
You are welcome. At least we found the root cause of this situation.
Have a nice day.
Nestor C
