Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
S3700 SSD SATA2 mode instead of SATA3
Hello!
I have several Intel SSD DC 3700 Series drives.
100GB, 200GB and 400GB and all have firmware 5DV12270.
100GB and 400GB drives work fine but the 200GB SSD works only in SATA2 mode with the same ports (SATA3) and cables (SATA3) with which the 100GB and 400GB drives work as SATA3 mode.
What could be the problem?
Community Manager
Here is output of isdct:
- Intel SSD DC S3700 Series -
AccessibleMaxAddressSupported : False
AggregationThreshold : Device does not support this command set.
AggregationTime : Device does not support this command set.
ArbitrationBurst : Device does not support this command set.
BusType : 11
CoalescingDisable : Device does not support this command set.
ControllerCompatibleIDs : PCI\\VEN_8086&DEV_1E02&REV_04PCI\\VEN_8086&DEV_1E02PCI\\VEN_8086&CC_010601PCI\\VEN_8086&CC_0106PCI\\VEN...
ControllerDescription : @oem23.inf,%pci\\ven_8086&dev_1e02&cc_0106.devicedesc%;Intel(R) 7 Series/C216 Chipset Family SATA AHCI Controller
ControllerID : PCI\\VEN_8086&DEV_1E02&SUBSYS_84CA1043&REV_04\\3&11583659&0&FA
ControllerIDEMode : False
ControllerManufacturer : @oem23.inf,%intel%;Intel Corporation
ControllerService : iaStorA
DIPMEnabled : False
DIPMSupported : False
DevicePath : \\\\.\\PHYSICALDRIVE0
DeviceStatus : Healthy
DigitalFenceSupported : False
DownloadMicrocodePossible : True
DriverDescription : Intel(R) 7 Series/C216 Chipset Family SATA AHCI Controller
DriverMajorVersion : 12
DriverManufacturer : Intel Corporation
DriverMinorVersion : 8
DriverVersion : 12.8.0.1016
DynamicMMIOEnabled : The selected drive does not support this feature.
EnduranceAnalyzer : 3635.46 years
ErrorString :
Firmware : 5DV12270
FirmwareUpdateAvailable : The selected Intel SSD contains current firmware as of this tool release.
HDD : False
HighPriorityWeightArbitration : Device does not support this command set.
IOCompletionQueuesRequested : Device does not support this command set.
IOSubmissionQueuesRequested : Device does not support this command set.
Index : 0
Intel : True
IntelGen3SATA : True
IntelNVMe : False
InterruptVector : Device does not support this command set.
IsDualPort : False
LatencyTrackingEnabled : The selected drive does not support this feature.
LowPriorityWeightArbitration : Device does not support this command set.
Lun : 0
MaximumLBA : 390721967
MediumPriorityWeightArbitration : Device does not support this command set.
ModelNumber : INTEL SSDSC2BA200G3
NVMePowerState : Device does not support this command set.
NativeMaxLBA : 390721967
OEM : Generic
OpalState : Unsupported
PLITestTimeInterval : 10080 minutes
PNPString : SCSI\\DISK&VEN_INTEL&PROD_SSDSC2BA200G3\\4&15828421&0&000000
PathID : 0
PhySpeed : 6.0 Gbps
PhysicalSectorSize : 4096 bytes
PhysicalSize : 200049647616
PortNumber : 0
PowerGovernorAveragePower : 8500 milliwatts
PowerGovernorBurstPower : 9500 milliwatts
PowerGovernorMode : 0 Unconstrained. Limited by maximum budget
Product : Taylorsville
ProductFamily : Intel SSD DC S3700 Series
ProductProtocol : ATA
ReadErrorRecoveryTimer : 0
RemoteSecureEraseSupported : False
SCSIPortNumber : 0
SMARTEnabled : True
SMARTHealthCriticalWarningsConfiguration : Device does not support this command set.
SMARTSelfTestSupported : True
SMBusAddress : Device does not support this command set.
SMI : False
SSCEnabled : False
SanitizeBlockEraseSupported : True
SanitizeCryptoScrambleSupported : True
SanitizeSupported : True
SataGen1 : True
SataGen2 : True
SataGen3 : True
SataNegotiatedSpeed : 3.0 Gbs
SectorSize : 512
SecurityEnabled : False
SecurityFrozen : True
SecurityLocked : False
SecuritySupported : True
TCGSupported : False
TargetID : 0
TempThreshold : Device does not support this command set.
TemperatureLoggingInterval : 1 minute(s)
TimeLimitedErrorRecovery : Device does not support this command set.
TrimSize : 6
TrimSupported : True
VolatileWriteCacheEnabled : Device does not support this command set.
WWID : 2778522436000306637
WriteAtomicityDisableNormal : Device does not support this command set.
WriteCacheEnabled : True
WriteCacheReorderingStateEnabled : True
WriteCacheState : 1
WriteCacheSupported : True
WriteErrorRecoveryTimer : 0
eDriveSupported : False
Community Manager
Hi fptas1979,
That's a weird behavior as your other drives are working correctly under the same conditions according to your description.
In some cases, issues related to SATA modes may be related to the BIOS and chipset used. Although this may not be the root cause here, I still recommend you to check that the BIOS and chipset are updated.
On the other hand, have you tried to use those drives in another system just to see if the same behavior happens?
Additionally, could you please share the Intel® SSD DCT output for the other drives and the SMART details of all drives too?
Please confirm also if you are using the drives as storage or bootable units.
I'll be waiting for your response.
Have a nice day.
Diego V.
Community Manager
Hello!
Thanks for the answer!
Today I tried my drives on another test desktop motherboard Asus H110M. It has 4 SATA3 ports.
The OS was installed on the WD 1 TB HDD.
All SSD drives were used as a storage.
I connected my Intel DC S3700 drives (100, 200 and 400 GB models). 200GB model worked in SATA2 mode.
The output of isdct is in the file 1.txt.
Then I disconnected the cables from 200 and 400 GB drives (but not from the motherboard) and exchanged the cables. The result was the same (file 2.txt)
Then I disconnected the cables from the 200 and 100GB models and exchanged them.
Again 200GB worked in the mode SATA2 (3.txt)
Smart details is in the file 1smart.txt
I do not know what else to do.
I also think that before updating the firmware from 5DV10270 to 5DV12270 the drive worked in SATA3 mode, but I did not have any screenshots, logs or anything similar to confirm this.
Is it possible to downgrade the firmware from 5DV12270 to 5DV10270?
How?
Community Manager
Thank you for the information and detailed description.
Please let me investigate about this issue because I'm not sure why it's happening. However, it's interesting that it worked fine on the previous firmware version.
I haven't seen any reports about this issue after updating the firmware to the latest one. I'll investigate on this as well. Unfortunately, it's not possible to downgrade the firmware.
I'll post here my findings as soon as possible.
Have a nice day.
Diego V.
Community Manager
Hi fptas1979,
I've been trying to reproduce the behavior you are describing but I'm not able to get the same result.
I've sent you a private message with additional instructions about how to proceed from this point. Please check it in your inbox.
Have a nice day.
Diego V.
Community Manager
Hello!
After many tests with different motherboards, drivers, cables and so on I was very frustrated.
Then I came up with the idea to change or reinstall the drive parameters in isdct with hope that after that the drive will work as it should.
Setting PhyConfig = 0, 2, 1 gave nothing.
Then I decided to change PhySpeed.
Description:
PhySpeed- Changes the devices maximum allowed PHY Speed it is allowed to negotiate. Valid values are:
- 1.5: SATA Gen 1 speed of 1.5 Gbs
- 3: SATA Gen 2 speed of 3 Gbs
- 6: SATA Gen 3 speed of 6 Gbs
Previously for my drive I got:
PhySpeed: 6.0 Gbps
SataNegotiatedSpeed: 3.0 Gbs
And I thought that my drive was set to PhySpeed=6, but it only works at 3 Gbs.
I ran the "isdct set -intelssd PhySpeed = 1.5" and rebooted the computer.
The "isdct show" showed me this:
PhySpeed: 6.0 Gbps
SataNegotiatedSpeed: 1.5 Gbs
Then my heart pounded, because I realized what it could mean.
I ran the "isdct set -intelssd PhySpeed = 6" and rebooted the computer.
PhySpeed: 6.0 Gbps
SataNegotiatedSpeed: 6.0 Gbs
Other test programs also showed that the drive is running in SATA3 mode and the transfer rate was consistent with this!
So, I realized that the value of PhySpeed in the output of the "isdct show" most likely shows the constant value of the fastest protocol revision, on which the drive can work (SATA1, SATA2, SATA3), not the current set value of this parameter.
Community Manager
Hi fptas1979,
It's great that all SSDs are working fine.
Thanks for sharing.
Diego V.
