Solid State Drives
Support for Issues Related to Intel® Solid State Drives
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
4365 Discussions
S3700 SSD server configuration recommendation
BOswa
I am putting together a server needing about 400GB of storage. Using S3700 SSDs, which of the following configurations is recommended?:
  • One 400GB drive
  • Two 400 GB drives in raid 1
  • Two 200GB drives in raid 0
  • Three 200GB drives in raid 5
  • Four 200GB drives in raid 10
We will initially be using about 250GB of capacity in for a Win 2012 server. With hard drives I would use a raid 5 or 10, but with a product as robust as the S3700, I am open to other opinions. Backups are performed daily.
Thanks for your help.
Jose_H_Intel1
Hello engene,
In this case we recommend you to verify with the system, motherboard or RAID controller manufacturer regarding the compatibility and TRIM support. They may have a list of validated models.
