Community
cancel
Showing results for
Search instead for
Did you mean:
BLaHa
SFF-8369 cable
I have a 2.5" Intel P3600 that I would like to use with a system that has an M.2 slot. While the M.2 to SFF-8643 adapter can be easily purchased online, I cannot seem to find a source for a cable from the SFF-8643 connector to the SFF-8639 connect. Given that Intel ships such a cable with the 750 series SSDs, is it possible to obtain the cable Intel ships separately from the 750 series SSDs? This is a pretty critical piece of the puzzle for using these SSDs.
ASouz7
Hello bcrl,
For the time being, these cables are not available separately. Thank you very much for your input. We are forwarding your inquiry to the proper department.
Unfortunately we do not have an specific time for an answer yet.
ASouz7
Hello bcrl,
