Community
cancel
Showing results for
Search instead for
Did you mean:
VBala7
SMART data on SSDs DC S3500 120GB
Jump to solution
I purchased two SSDs (DC S3500 120GB) via ebay and would appreciate
if someone could comment on the SMART values - the SSDs were supposed
to be new - I can see that they have been written to (not new), but I'm
more concerned about the other values.
I used CrystalDiskInfo as Intel SSD toolbox doesn't work
over USB - I've only got a few old pcs with PATA (I'm in the
middle of building a new server with SATA)
jbenavides
Hello vjekobalas,
Here are the main things I noticed from the S.M.A.R.T. information you provided:
- As you suggested, the drives show some usage (Power Counts, Writes and Reads) this is noted in the report summary and the SMART data, however, it is minimum (300+ GB and 10+ GB) when compared to the endurance ratings expected from the Intel® SSD DC S3500.
- The SMART counters that would be related to any issues in the drive are OK. Bad sectors, errors, failures and wearout are all clean.
You can review the details about the SMART attributes in thehttp://www.intel.com/content/dam/www/public/us/en/documents/product-specifications/ssd-dc-s3500-spec... Intel® SSD DC S3500 series - Product Specification, pages 21-24.
jbenavides
Hello vjekobalas,
VBala7
Hi jonathan_intel,
Thanks for the info/specs -your comments and a check of the specs
on the temp/power loss values (which concerned me on first sight)
have convinced me to keep the SSDs although they aren't new as advertised.
thanks again ! - time for installation.
