Community
cancel
Showing results for
Search instead for
Did you mean:
RShar23
SMART data reading from Intel NVMe PCIe P3700 series SSD
I want to use Intel P3700 series NVMe PCIe SSD to read SMART attributes exposed by the device using our user land customized tool. The device will be placed on Gen 3.0 x4 motherboard having linux as OS (kernel 3.13) and RAM 4GB.
Please suggest if any other requirements are needed to read SMART data out of Intel P3700 series SSD.
ASouz7
Hello ravish165,
You will need to use Linux* kernel 3.19 for this drive. Please take a look at information in this link: http://downloadmirror.intel.com/23929/eng/Intel_Linux_NVMe_Driver_Reference_Guide_330602-002.pdf Intel® Linux* NVMe* Driver it is a PDF and you can find all the information you need on page 4. Intel recommends to use the Intel® SSD Datacenter Tool. You can find it here: https://downloadcenter.intel.com/download/23931/Intel-Solid-State-Drive-Data-Center-Tool Intel® Download Center
RShar23
Hi aleki_intel,
Information was good and help to manage our requirements.
So if I upgrade kernel version to 3.19 then I can use intel p3700 series nvme ssd on my desktop system having Gen 3.0 x4 motherboard.
RAM can be upgraded to 8 GB,thats not an issue.
Actually I wanted to understand the hardware/software requirements to use intel p3700 series ssd on desktop systems. Will there be be any performance issue using this ssd on desktop.
ASouz7
ravish165,
The Intel® SSD DC P3700 Series was designed to be used with Enterprise Systems, however, we have reports from other customers using it in high-end desktop systems. In order to use it, your computer needs to meet all the necessary requirements found here: http://www.intel.com/content/dam/www/public/us/en/documents/product-specifications/ssd-dc-p3700-spec... Intel® Solid-State Drive DC P3700 Series Product Specification
For your convenience, please take a look at the installation guide here: http://downloadmirror.intel.com/23929/eng/Intel%20SSD%20Data%20Center%20Family%20for%20PCIe%20Instal... Intel® Solid State Drive Data Center Family for PCIe* P3700, P3600 and P3500 Series
ASouz7
Ravish165,
We also noticed that you did not mention what chipset was the intended. Please be aware that the Intel® SSD DC P3700 Series has a management capability which can conflict with desktop chipsets memory address and prevent booting. There may be workarounds but please be sure to test your intended configuration. With the intention to widen your possibilities only, we also would like to inform you that with the Intel® X99 Chipset it's likely to work and with the Intel® Z97 Chipset the card may only work in one PCIe* slot or using one memory DIMM ((Dual In-line Memory Module) to boot. The Intel® SSD 750 Series may be more compatible and offer similar performance without management SMBUS (System Management Bus) if the type of usage intended works with it.
RShar23
aleki_intel,
Thanks for the information.
Can we use Intel P3500 series SSD on PCIe Gen 2.0 motherboard ? We don't want to write any heavy data on drive and just wanted to use drive to read SMART attributes using our utility based on nvme to read SMART attributes form nvme device.When our budget issues get resolved then will look forward to buy PCIe Gen 3.0 motherboards. But currently we have PCIe Gen 2.0 motherboard.
Our Base Board Information
Manufacturer: Dell Inc.
Product Name: 03NVJ6
Version: A01
Serial Number: ..CN7360406E040I.
ASouz7
ravish165,
The Intel® SSD DC P3500 Series was designed to meet the standards available in the market: http://www.intel.com/content/dam/www/public/us/en/documents/product-specifications/ssd-dc-p3500-seri... Intel® Solid-State Drive DC P3500. The drive may show degraded performance if plugged into a slot that is not PCIe Gen 3.0. Check on page # 6 of this online document: http://downloadmirror.intel.com/23929/eng/Intel%20SSD%20Data%20Center%20Family%20for%20PCIe%20Instal... Intel® Solid-State Drive Data Center Family for PCIe* P3700, P3600 and P3500 Series Installation Guide- Please, also consult with the motherboard manufacturer for further assistance.We hope this information helped you.
RShar23
aleki_intel,
Thanks for the information and documents.
From the documents I understood that intel p3500 ssd will be backward compatible with PCIe Gen 2.0 card slots.
Kindly confirm so that we can go ahead and purchase.
ASouz7
ravish165,
The Intel® SSD DC P3500 Series may work as a data drive when connected to a PCIe Gen 2 slot as long as the system complies with the requirements. It is explained in the installation guide document provided before. I would like to mention that some older systems may not work with the NVMe* drive connected. There may be a resource conflict. If you intend to you a server chipset with PCIe 2.0 then the SSD may have no conflict. Remember to always consult with the board manufacturer for further assistance as well.
RShar23
aleki_intel,
We have hp proliant server (HP ProLiant DL380 Generation 7 (G7) ) having Intel® 5520 Chipset with 16GB RAM .On that can we connect intel p3500 ssd?
Any hardware or software changes needs to be done to use ssd on proliant server?
Can we connect intel 750 series nvme ssd if p3500 ssd is not compatible with proliant server?
RShar23
aleki_intel,
need your inputs.
Wanted to use Intel 750 series nvme AIC ssd on Asus Z97-K motherboard. We don't want to use drive for heavy write purposes. Just wanted to read few of the attributes from the device.Our current planned configuration is :motherboard - Asus Z97-K CPU - Intel Core 2 Duo RAM - 4GB DDR3Seagate Barracuda 7200.12 160GB hard disk used as primary storage Power Supply - same as used in desktop systems (wanted to use Dell motherboard system power supply with Asus Z97-K motherboard-is this possible)Intel 750 series ssd as secondary storage on PCIe Gen 3.0 slotKindly share inputs if above configuration is suitable to use intel 750 series ssd.
RShar23
For using Intel 750 Series SSD on desktop systems as secondary drive I have planned for system configuration as:
Motherboard - Asus Z-97 A
CPU - 4th generation i3
Power Supply - 500W or 750W
RAM - DDR3 4 GB
Primary storage - Seagate ST3400832A 400GB 7200 RPM (Bootable device)
OS - Linux based Fedora core 20 or Cent OS 6.5
Kindly review and share opinion about system configuration (additional hardware needed?) for using Intel 750 series ssd on desktop systems. My requirement is NOT doing performance testing of SSD so need a system which can properly detect and read/write data blocks/log pages using NVMe standard from SSD.
