Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
SSD 320 hangs after prompting for password
I have a 160gb 320 SSD in my Lenovo W510 laptop. It has worked well, but today, win7 suddenly hung with the drive light on. After a few minutes I cold-booted the machine.
The SSD has the ATA password set, and the prompt came up as normal. However, once I hit enter after typing in the password, the machine hangs, again with the HDD light on.
If I remove the ssd, replace it with another identical 320 ssd and boot from the replacement, then insert the original non-functional ssd into the drive bay, intel RST identifies the faulty drive, its size, serial number, firmwaver version and that it is locked. It also provide the unlock functionality, but it seems to have a lower limit of characters available for providing a password than does the Lenovo BIOS - so it failed the attempt to unlock the drive from RST.
Drive model: INTEL SSDSA2CW160G3
firmware: 4PC10362
Is there anything else I can try, or is the only solution to return the drive as defective?
Thanks!
Tags (1)
Community Manager
funny, it looks like I was able to enter a 35-character password via the Lenovo Bios (it did not allow 36). This has worked for months and months with no problem, and still works for the drive that is functional.
the RST allows only 32 characters for the ata pwd, which is according to specification.
I have no idea if this has anything to do with it - I would suppose not, since the other drive works fine with such a long password.
Any ideas?
Community Manager
Did you ever find a solution to your problem? or perhaps contacted customer support?
I am in a very similar situation, i experienced a BSOD in windows 7 on my laptop (thinkpad t410). and now it just stalls after i input the correct password (that i have been using daily for the last year).
I also have the same symptom, that i can not enter BIOS when the SSD is plugged in.
Community Manager
The same problem with Lenovo Thinkpad x201 and intel ssd 320. Guys have you solve it?
