Hello, I had a ssd drive 320 series 300GbiB, the problem it's that when it's recognized it's showed like "IntelBootloader" on model number and "NO FW FOUND" in serial number a screen shot from the hdparm linux utility
ATA device, with non-removable media
Model Number: IntelBootloader ▒&▒&▒&t#
Serial Number: NO FW FOUND
Firmware Revision: 4B1B006B
Transport: Serial, ATA8-AST, SATA 1.0a, SATA II Extensions, SATA Rev 2.5, SATA Rev 2.6
Standards:
Used: ATA/ATAPI-7 T13 1532D revision 1
Supported: 7 6 5 4
Configuration:
Logical max current
cylinders 16383 16383
heads 16 16
sectors/track 63 63
CHS current addressable sectors: 16514064
LBA user addressable sectors: 16384
Logical/Physical Sector size: 512 bytes
device size with M = 1024*1024: 8063 MBytes
device size with M = 1000*1000: 8455 MBytes (8 GB)
cache/buffer size = unknown
Nominal Media Rotation Rate: Solid State Device
Capabilities:
LBA, IORDY(can be disabled)
Standby timer values: spec'd by Standard, no device specific minimum
R/W multiple sector transfer: Max = 1 Current = 1
DMA: mdma0 mdma1 mdma2 udma0 udma1 udma2 udma3 udma4 *udma5
Cycle time: min=120ns recommended=120ns
PIO: pio0 pio1 pio2 pio3 pio4
Cycle time: no flow control=120ns IORDY flow control=120ns
Commands/features:
Enabled Supported:
* Power Management feature set
* Mandatory FLUSH_CACHE
* Gen1 signaling speed (1.5Gb/s)
* Gen2 signaling speed (3.0Gb/s)
Security:
Master password revision code = 65534
2min for SECURITY ERASE UNIT. 2min for ENHANCED SECURITY ERASE UNIT.
Checksum: correct
Can you help my how can I solve that problem ???
Hello fantomsam,
We understand that you're having some recognition issues where your HDPARM utility is unable to properly identify your Intel® SSD. The odd thing here is that HDPARM is still able to read the firmware version of your drive (4B1B006B), even if this does seem to be an outdated version.
Please keep in mind that we don't provide support for third-party tools. However, we can still provide you some troubleshooting suggestions in a best efford basis.
1. If you're connecting your SSD using a SATA to USB adapter, please try connecting the drive directly through SATA.
2. Download and boot off our latest Intel® Firmware Update Tool. If your drive is detected, please update to the latest firmware (should be firmware version 4PC10362).
3. Using HDPARM, or one of these http://www.intel.com/content/www/us/en/support/memory-and-storage/000006198.html third-party tools, perform a secure erase (low-level format) on your SSD.
Aside from the issue on HDPARM, does your SSD display properly on your OS?
We look forward to hearing back from you.
Carlos A.
Edit: Fixed link for Low-Level Format Article.
Hello fantomsam,
We haven't heard from you in a while, did our suggestions help resolve your issue?
If you need any further assistance, feel free to contact us again.
Carlos A.
Hello fantomsam,
We do not have any viable troubleshooting for this type of errors. At this point, it's safe to say that your SSD has failed.
Our best recommendation will be to http://www.intel.com/content/www/us/en/support/contact-support.html contact support to check your warranty status and replace your drive if possible.
Carlos A.
