cancel
Showing results for
Search instead for
Did you mean:
SSD 510 Series Drive Access Lockup
Esteemed Contributor III
I am seeing some odd behavior with my SSDSC2MH250A2 drives. I have two of these connected to my DX58SO2 motherboard. What was happening was that access to my second SSD drive would cause Windows to freeze. The OS itself would hang while trying to access to drive. I was not sure what was causing this, and I thought I had defective hardware at first.
I had to hold down the power button due to some of these freezes. After doing this, I ran a chkdsk /f for both drives followed by rebooting to ensure the file system was intact. My second SSD drive was even freezeing or extremely slow during the chkdsk. I had to hold down the power button during one chkdsk after it reported unexpected errors.
I ran Intel's SSD Toolbox followed by running the SSD Optimizer for both drives. After doing this, the freezing issues seemed to have stopped. Here is where I am confused though-- I am running Windows 7 Professional, and the Intel PDFs I have read stated that the functionality of the SSD Optimizer is built into Windows 7. This leads me to believe I should not need to run the optimizer.
I do not understand why the SSD drives would cause the OS to hang after about three weeks of use. I can find no firmware updates for the 510 series at all.
25 REPLIES 25
I did a scan with HDTune Pro and found some sectors to be broken, so I sent the SSD back for repair. After two weeks, they sent me a brand new one and it seems to be working perfectly now.
