cancel
Showing results for
Search instead for
Did you mean:
SSD 520 series 240GB failed, any possibility to recover the data from it?
cpave
New Contributor
SSD 520 series 240GB failed, not detected in BIOS, servcemen say the controller failed, any possibility to recover the data from it? two recovery-services said it is impossible to decrypt data without controlled, maybe i can buy another ssd of the same serie?
1 REPLY 1
Alek_S_Intel
New Contributor
saarem,
In your particular case, it is best if you contact your nearest Intel Contact Center, here is the link: http://www.intel.com/content/www/us/en/support/contact-support.html Contact Support and check with one of our technicians for the best option for the assistance you need. Please have handy the ISN and SA of your SSD so the technician can pull up the information on the drive.
