Community
cancel
Showing results for
Search instead for
Did you mean:
DFong
SSD 530 Blue Screen when starting Intel SSD Toolbox
I just installed the SSD 530 (480GB) into my PC and every time I try and start the Intel SSD Toolbox I get a Blue Screen and my system crashes.
What do I need to do in order to properly use the Toolbox to perform firmware updates?
Tags (1)
Jose_H_Intel1
Hi akiranyc, there are a few threads dealing with the same issue in the /community/tech/solidstate/content Intel® SSD Community, such as the ones included below:
If your issue is not solved with the steps provided in any of these discussions, kindly share more details about your system. Please include the system model, and http://www.intel.com/support/siu.htm Intel® System Identification Utility or msinfo32 report (press Windows* key + R key, type "msinfo32", press OK and then File, Export).
Attachments are available from the Advanced Editor when replying.
Jose_H_Intel1
If you have Windows* 8.1, please install the following Windows* update as it has been proved to solve issues with Intel® SSD Toolbox.
http://support.microsoft.com/kb/3000850 http://support.microsoft.com/kb/3000850
