I need to flash my Intel SSD 540S, I create a bootable USB-drive based on this SSD-image. Firmware Update Tool 2.1.7, guided by this guide http://www.intel.com/content/dam/support/us/en/documents/solid-state-drives/Intel_SSD_FUT_2.1.x_User... http://www.intel.com/content/dam/support/us/en/documents/solid-state-drives/Intel_SSD_FUT_2.1.x_User... the problem is that the flash drive starts but stops loading the FTU shell. Add screenshot
Hello Vadimm238,
We understand you are having issues upgrading the firmware on the SSD, due to the FUT error during the boot process. We'd like to let you know that if you have a system running Windows* as the operating system, you can also use the https://downloadcenter.intel.com/download/26378/iRMFUU-for-Intel-SSD-540s-Pro-5400s-E-5400s-DC-S3100... following tool, we have tested it and it works fine.
Please follow the instructions inside the zip package in order to properly update it.
Let us know if this worked.
Nestor C
Hello Vadimm238,
Nestor C
Hi Vadimm238,
We are glad to see that the tool worked properly. In the case of further assistance, do not hesitate to contact us back.
Nestor C
Tell me please where can I see the history of firmware changes since the first release? I found the description of firmware 031 and 036 Thank you in advance.
Hi Vadimm238,
Please enter the https://downloadmirror.intel.com/26491/eng/Intel_SSD_Firmware_Update_Tool_2_1_7_Release_Notes_015.pd... following link and go to page 11. In there you will find "Intel® Solid State Drive 540s Series Revision History".
Nestor C
