Hi Everyone,
I am having issues with the 10 pieces of SSD's that 'm using.
the SSD' are Intel 545s 256GB.
I'm getting the following error after fully long initialising the SSD using Dell IDrac9.
On the Idrac9 dashboard all seems to be OK , but the errors are on Freenas:
Feb 14 18:06:20 VNAS smartd[7531]: Device: /dev/da7 [SAT], FAILED SMART self-check. BACK UP DATA NOW!
Feb 14 18:06:20 VNAS smartd[7531]: Device: /dev/da7 [SAT], Failed SMART usage Attribute: 184 End-to-End_Error.
Feb 14 18:06:21 VNAS smartd[7531]: Device: /dev/da12 [SAT], FAILED SMART self-check. BACK UP DATA NOW!
Feb 14 18:06:21 VNAS smartd[7531]: Device: /dev/da12 [SAT], Failed SMART usage Attribute: 184 End-to-End_Error.
Feb 14 18:06:22 VNAS smartd[7531]: Device: /dev/da13 [SAT], FAILED SMART self-check. BACK UP DATA NOW!
Feb 14 18:06:22 VNAS smartd[7531]: Device: /dev/da13 [SAT], Failed SMART usage Attribute: 184 End-to-End_Error.
Feb 14 18:06:22 VNAS smartd[7531]: Device: /dev/da10 [SAT], FAILED SMART self-check. BACK UP DATA NOW!
Feb 14 18:06:23 VNAS smartd[7531]: Device: /dev/da10 [SAT], Failed SMART usage Attribute: 184 End-to-End_Error.
Feb 14 18:06:23 VNAS smartd[7531]: Device: /dev/da9 [SAT], FAILED SMART self-check. BACK UP DATA NOW!
Feb 14 18:06:24 VNAS smartd[7531]: Device: /dev/da9 [SAT], Failed SMART usage Attribute: 184 End-to-End_Error.
I have tried full initialisation and Clear (Who takes around 30 mins) using IDRAC9
Also Cryptographic erase.
I keep getting the errors in Freenas (FreeBSD) linux distro.
Please advice, Many thanks
Another thing I forget to mention is, the SSD's are very new, so it less reasonable that these are defective.
Hello, Phoenix.
Good day,
Thank you for contacting the Intel Community Support.
I checked your ticket regarding the SMART errors with the Intel SSD 545s, I will be glad to assist you.
The Intel® SSD 545s Series of drives is not validated to be used in server or data center environments, and could possibly be one of the reasons why the number of End-to-End Error count increased up to a point to generate an alert with the tool you are using.
Check the drive using the Intel SSD Toolbox, preferably using a regular desktop computer running a compatible version of Windows.
Download: https://downloadcenter.intel.com/download/29205/Intel-Solid-State-Drive-Toolbox
With this tool you can:
You can export the SMART report to a file and then attach the file to this thread, that way I can take a look at the status of the drive (or drives).
I hope to hear from you soon.
Bruce C.
A Contingent Worker at Intel
Hi Bruce,
thanks for your answer.
It’s important to mention few points.
i am using the server for personal use and the load in I/O write/read from the disks is very minimal (the server will be up only few hours a day), data write read on the intel SSD‘s have not passed even 20Gb.
i opened the disks from the original package two weeks ago.
unfortunately I don’t use Windows at all, just Linux/Unix.
i need to know how can I initialize the ssds without the smart errors.
also the information from intel I found over the internet is recommending 3rd tools that I don’t want to use, why the built in tools from Dell Idrac are not enough for that (intel is OEM manufacturer, right?)
i have other tlc based consumer ssds (crucial, Samsung, etc, and those works well)
i know that consumer ssds wear out is faster then enterprise 3D nand and so on but having the disks showing smart errors while being really new is unacceptable.
thanks on advance
Hello, Phoenix.
Thank you for the information.
We don't have a tool or special steps to "Initialize the SSD without the SMART errors".
In Linux you can use the Intel® Memory and Storage Tool CLI, it can be used to delete, perform a firmware update and get the SMART information from the disk:
If you are certain about the units being defective from the start and since you recently bought the drives, the best option would be to go back to the place of purchase.
Bruce C.
Hello, Phoenix.
I wanted to follow up on your thread regarding the Intel SSD 545s Series.
If you have any questions or concerns and I can be of assistance, please let me know.
Bruce C.
Hi Bruce,
eventually I ended up sending the ssd back reclaiming my warranty for a replacement.
i have noticed that the wear out was way to big compared to my use of disks, not more then two or three weeks where i did write minimal data on them and only deep initialize those one or two times.
Hello, Phoenix.
Thank you for letting me know.
It's strange for these drives to be degraded after so little use, especially since you mentioned that it was a really light workload.
I will proceed to close the ticket right now, if you need any type of assistance from Intel in the future, you can always contact us back; you may also reply to this message within 14 days to re-open it.
Bruce C.
