Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
SSD 545s Series - "was not migrated"
Model: INTEL SSDSC2KW512G8
Firmware Version: LHF002C
I just install the ssd a few days ago using Intel Data Migration Software build 19.0.1044
My PC is booting OK and have not seen anything strange until finding the following error.
My search on the web has not solved the problem.
Thanks for you help.
Error Message
Device SCSI\Disk&Ven_INTEL&Prod_SSDSC2KW512G8\4&33112d1f&0&000000 was not migrated due to partial or ambiguous match
Last Device Instance Id: USBSTOR\Disk&Ven_Verbatim&Prod_STORE_N_GO&Rev_5.00\078312A20EFF&0
Class Guid: {4D36E967-E325-11CE-BFC1-08002BE10318}
Location Path:
Migration Rank: 0xF000FC00FFFFF130
Present: false
Status: 0xC0000719
Drivers:
C:\Windows\System32\drivers\disk.sys 10.0.16299.15
C:\Windows\System32\drivers\EhStorClass.sys 10.0.16299.15 (WinBuild 160101.0800)
C:\Windows\System32\drivers\fltsrv.sys 1.3.0.2195 Acronis International GmbH
C:\Windows\System32\drivers\hpdskflt.sys 7.01.1 HP Development Company
C:\Windows\System32\drivers\partmgr.sys 10.0.16299.15 (WinBuild 160101.0800)
Highlighted
Community Manager
Re: SSD 545s Series - "was not migrated"
Hi Leland,
Thank you for contacting our support community. We understand your concern regarding the cloning process.
In order to better understand your situation, could you please confirm the following information:
-Could you please let us know the Operating System you are running?
-Could you please let us know where do you get the error message? If possible, please attach screenshots when you get the error.
-Please provide the brand and model of your system.
We look forward to hearing back from you.
Junior M.
Thanks for looking into this.
Leland
OS Name Microsoft Windows 10 Home
Version 10.0.16299 Build 16299
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Name REDACTED
System Manufacturer Hewlett-Packard
System Model HP ENVY TS 15 Notebook PC
System Type x64-based PC
System SKU C8P48AV
Processor Intel(R) Core(TM) i7-4700MQ CPU @ 2.40GHz, 2401 Mhz, 4 Core(s), 8 Logical Processor(s)
BIOS Version/Date Insyde F.70, 10/20/2017
Highlighted
Community Manager
Hi Leland,
Thanks for the reply.
We will investigate your situation with our additional resources. We will keep you posted with any updates.
Junior M.
Highlighted
Community Manager
Hi Leland,
Could you please let us know if you updated from and different version of Windows* to Windows (R)10 and after that, you cloned the SSD? or did you perform a clean Windows(R) 10 installation and cloned the SSD?
Junior M.
Highlighted
Community Manager
Hi Leland,
We would like to know if you read our previous post. If you have any other questions, we'll be waiting for your response.
Junior M.
