Intel® Optane™ Solid State Drives
Support for Issues Related to Solid State Drives based on Intel® Optane™ technology, Intel® MAS and Firmware Update Tool
435 Discussions
SSD Data Center tools in ESXi do not see SSD DS S3520
Ndf
Hellow.
"SSD Data Center tools" do not see the SSD drive. (tried 3.0.4 and 3.0.7)
SSD DS S3520 firmware N2010112.
Tried ESXi 5.5 U1 and 6.5.
I have two servers based on motherboards ASUS P9D-M with chipset C224 with LSI® MegaRAID on board (no RAID in AHCI mode) and "server" ASUS on H67-V (in AHCI mode).
I did everything in accordance with the documentation.
- SSDs are connected to the SATA port directly. AHCI mode. (no RAID)
- VIB installed
Try:
/ opt / intel / isdct # ./isdct show -intelssd
And all the time i see the same thing: - "No results"
What did I miss?
~ # esxcli storage core device list
t10.ATA_____INTEL_SSDSC2BB480G7_____________________PHDV73710800480BGN__
Display Name: Local ATA Disk (t10.ATA_____INTEL_SSDSC2BB480G7_____________________PHDV73710800480BGN__)
Has Settable Display Name: true
Device Type: Direct-Access
Multipath Plugin: NMP
Devfs Path: /vmfs/devices/disks/t10.ATA_____INTEL_SSDSC2BB480G7_____________________PHDV73710800480BGN__
Vendor: ATA
Model: INTEL SSDSC2BB48
Revision: N201
SCSI Level: 5
Is Pseudo: false
Status: on
Is RDM Capable: false
Is Local: true
Is Removable: false
Is SSD: true
Is Offline: false
Is Perennially Reserved: false
Queue Full Sample Size: 0
Queue Full Threshold: 0
Thin Provisioning Status: yes
Attached Filters:
VAAI Status: unknown
Other UIDs: vml.010000000050484456373337313038303034383042474e2020494e54454c20
Is Local SAS Device: false
Is Boot USB Device: false
No of outstanding IOs with competing worlds: 32
~ # esxcli storage core path list
sata.vmhba0-sata.0:0-t10.ATA_____INTEL_SSDSC2BB480G7_____________________PHDV73710800480BGN__
UID: sata.vmhba0-sata.0:0-t10.ATA_____INTEL_SSDSC2BB480G7_____________________PHDV73710800480BGN__
Runtime Name: vmhba0:C0:T0:L0
Device: t10.ATA_____INTEL_SSDSC2BB480G7_____________________PHDV73710800480BGN__
Device Display Name: Local ATA Disk (t10.ATA_____INTEL_SSDSC2BB480G7_____________________PHDV73710800480BGN__)
Adapter: vmhba0
Channel: 0
Target: 0
LUN: 0
Plugin: NMP
State: active
Transport: sata
Adapter Identifier: sata.vmhba0
Target Identifier: sata.0:0
Adapter Transport Details: Unavailable or path is unclaimed
Target Transport Details: Unavailable or path is unclaimed
Maximum IO Size: 33553920
Hi Sptta,
We understand the situation regarding the Intel® SSD Data Center Tool.
Could you please confirm if the SSD is connected directly to the motherboard? If not, we suggest you connect the SSD directly to the motherboard because the Intel® SSD Data Center Tool is not able to see the SSD's when it is not connected directly to it.
We look forward to hearing back from you.
Junior M.
Ndf
Hellow/
Yes, SSD directly connected. SATA ports in AHCI mode.
Hi Sptta,
We would further investigate on this with our additional resources, we will keep you posted with any updates.
Junior M.
Ndf
Hi Junior M.
I see we are in different time zones. This is a problem. I do not want to spend the next 5 years on the issue.
The equipment still stands on my table. So if you need any configuration information, I'm ready to provide it.
Server 1:
MB: ASUS P9D-M rev 1.03
Server 2:
MB: ASUS P8H67-V rev 3.0
I repeat, I checked on ESHI 5.5 U1 and 6.5.
If you need anything to check or you need any information about the configuration, I'm ready to provide it.
Hi Sptta,
We would like to inform you that the https://downloadcenter.intel.com/download/27248?v=t latest version of the Intel® SSD Data Center Tool does not support VMware*. However, it seems that a https://downloadcenter.intel.com/download/27144/Intel-SSD-Data-Center-Tool previous version of the Tool(3.0.7) supports the following versions of ESXI* 5.5 or 6.0 as per our https://www.intel.com/content/dam/support/us/en/documents/memory-and-storage/Intel_SSD_DCT_3_0_x_User_Guide.pdf documents.
There's a note in the User Guide, page 7, that states that the user must set their ESXi* host acceptance level to "Community Supported" in order to install the tool.
Junior M.
Ndf
Hi.
I patched the SSD with the latest firmware. I tried to change the ports on the board. Tried to use EsXi 5.5, 6.0, 6.5. The result is the same.
In "Intel_SSD_Data_Center_Tool_3_0_7_User_Guide_331961-012.pdf" # 1.3 "Supported SSDs" i see my "DS S3520". It`s SATA. It`s directly connected to MB.
And it does not work. This is strange.
Do I have the wrong motherboard? Can I ask you to recommend me a desktop motherboard (or a chipset) on which it will definitely work? Or LSI Adapter...
Why ISDCT trying to search for NVMe?:
/opt/intel/isdct # ./isdct set -system EnableLog = 'true'
Set EnableLog successful.
/opt/intel/isdct # ./isdct show -intelssd
No results
TDKI.log
15:24:07:300533 [debug] tdk_interface_dll.cpp(259) SendXMLMessage: Entering
15:24:07:302121 [debug] TDKInterface.cpp(522) scan: Entering
15:24:07:302135 [debug] DeviceFinder_NVME.cpp(63) scan: Entering
15:24:07:302143 [debug] DeviceFinder_NVME.cpp(100) scanPhysicalDevices: Entering
15:24:07:302211 [error] Connection_Path.cpp(91) open: vmk_MgmtUserInit error: 19
15:24:07:302229 [error] DeviceFinder_NVME.cpp(134) scanPhysicalDevices: Failed to connect to device. Ignoring intel-nvme0
15:24:07:302265 [error] Connection_Path.cpp(91) open: vmk_MgmtUserInit error: 19
15:24:07:302274 [error] DeviceFinder_NVME.cpp(134) scanPhysicalDevices: Failed to connect to device. Ignoring intel-nvme1
15:24:07:302299 [error] Connection_Path.cpp(91) open: vmk_MgmtUserInit error: 19
15:24:07:305290 [error] Connection_Path.cpp(91) open: vmk_MgmtUserInit error: 19
15:24:07:305298 [error] DeviceFinder_NVME.cpp(134) scanPhysicalDevices: Failed to connect to device. Ignoring intel-nvme97
15:24:07:305321 [error] Connection_Path.cpp(91) open: vmk_MgmtUserInit error: 19
15:24:07:305329 [error] DeviceFinder_NVME.cpp(134) scanPhysicalDevices: Failed to connect to device. Ignoring intel-nvme98
15:24:07:305336 [debug] DeviceFinder_NVME.cpp scanPhysicalDevices: Exiting
15:24:07:305343 [debug] DeviceFinder_NVME.cpp scan: Exiting
15:24:07:305350 [debug] TDKInterface.cpp scan: Exiting
15:24:07:305447 [debug] tdk_interface_dll.cpp SendXMLMessage: Exiting
15:24:07:305455 [debug] tdk_interface_dll.cpp(303) ReceiveXMLMessage: Entering
15:24:07:305515 [debug] tdk_interface_dll.cpp ReceiveXMLMessage: Exiting
15:24:07:305523 [debug] tdk_interface_dll.cpp(303) ReceiveXMLMessage: Entering
15:24:07:305548 [debug] tdk_interface_dll.cpp ReceiveXMLMessage: Exiting
Hi Sptta,
We recommend you to try with other previous versions of the Intel® SSD Data Center Tool:
https://downloadcenter.intel.com/download/26749/Intel-SSD-Data-Center-Tool 3.0.4
https://downloadcenter.intel.com/download/26926/Intel-SSD-Data-Center-Tool 3.0.5
https://downloadcenter.intel.com/download/26970/Intel-SSD-Data-Center-Tool 3.0.6
Please keep in mind that those versions only work with ESXI* 5.5 or 6.0. Make sure you uninstall the previous version before proceeding.
The tool should not ask you for NVMe* drivers because this SSD is SATA, do you have other SSDs connected to the motherboard?
Could you please let us know where you found those logs?
Junior M.
Ndf
This log file was created in /var/log/ when i make ./isdct set -system EnableLog = 'true'.
In "Intel_SSD_Data_Center_Tool_3_0_7_User_Guide_331961-012.pdf" # .2.4.1 "Show tool configuration"
/opt/intel/isdct # ./isdct show -system
- ISDCT Config -
EnableLog: true
LogFile: /var/log/TDKI.log
Hi Sptta,
Thanks for the information provided.
Please let us know if you have the same output with the previous versions of the tool.
Junior M.
Ndf
I checked. Same.
I see that the new version 3.0.9 has been released. Interestingly, there will be a result. There is not yet for Vmware.
Hi Sptta,
Thanks for the information, it seems that the Firmware of the SSD is not the latest one. The latest version of the Firmware is N2010121.
We recommend you to follow the next steps in order to update it:
1- Go to https://downloadcenter.intel.com/download/26491/Intel-SSD-Firmware-Update-Tool https://downloadcenter.intel.com/download/26491/Intel-SSD-Firmware-Update-Tool
2- Download the issdfut_2.2.3.iso
3- Go to https://www.google.com/url%3Fq%3Dhttps%253A%252F%252Frufus.akeo.ie%252F%26sa%3DD%26sntz%3D1%26usg%3DAFQjCNFb4BRd6FkTrMVe1h2Bv3yMQO1B8w https://rufus.akeo.ie/and download Rufus.
4- Connect an empty USB flash drive to the PC.
5- Open Rufus and change only the options "Device" and select your USB. Then go to ISO image, click on search and select the issdfut_2.2.3.iso you previously downloaded.
6- Go to your BIOS -> Boot -> Boot priority -> select the "USB" as primary.
7- Re-boot your PC. It should enter the firmware update tool for your SSD.
8- Update the firmware and then boot windows.
9- If it does not boot the "USB" or it gives you an error, please go to BIOS and change the boot mode to "legacy only". Then try again.
NOTE: Any links provided for third party tools or sites are offered for your convenience and should not be viewed as an endorsement by Intel® of the content, products, or services offered there. We do not offer support for any third party tool mentioned here.
Please try it and let us know the results.
Junior M.
Ndf
I already did it. As soon as I saw the problem... SSD firmware updated.
May I ask you, could you clarify whether this is possible on 'my' chipsets at all? For me to buy another hardware is not a problem.
The problem - is not to get the job done...
Hi Sptta,
Thanks for the reply.
Based on the release notes for the Intel® SSD Data Center Tool there is no specific requirement related to the chipset.
We would investigate this with our additional resources. We would keep you posted with any updates.
Junior M.
Hi Sptta,
Could you please provide us with the Intel® SSD Data Center Tool logs.
Please run the following commands:
isdct set –system EnableLog=True • isdct set –system LogFile=myDCTlogfile.txt
Junior M.
Ndf
ESXi 6.5
Intel SSD Data Center Tool 3.0.7 (latest for VmWare)
[root@localhost:~] cd /opt/intel/isdct/
[root@localhost:/opt/intel/isdct] ./isdct set -system LogFile = 'myDCTlogfile.txt'
Set LogFile successful.
[root@localhost:/opt/intel/isdct] ./isdct set -system EnableLog = 'true'
[root@localhost:/opt/intel/isdct] ./isdct show -intelssd
No results
LogFile (/opt/intel/isdct/myDCTlogfile.txt):
19:06:21:250961 [debug] tdk_interface_dll.cpp(259) SendXMLMessage: Entering
19:06:21:253026 [debug] TDKInterface.cpp(522) scan: Entering
19:06:21:253049 [debug] DeviceFinder_NVME.cpp(63) scan: Entering
19:06:21:253061 [debug] DeviceFinder_NVME.cpp(100) scanPhysicalDevices: Entering
19:06:21:253161 [error] Connection_Path.cpp(91) open: vmk_MgmtUserInit error: 19
19:06:21:253191 [error] DeviceFinder_NVME.cpp(134) scanPhysicalDevices: Failed to connect to device. Ignoring intel-nvme0
19:06:21:253241 [error] Connection_Path.cpp(91) open: vmk_MgmtUserInit error: 19
19:06:21:253256 [error] DeviceFinder_NVME.cpp(134) scanPhysicalDevices: Failed to connect to device. Ignoring intel-nvme1
19:06:21:253292 [error] Connection_Path.cpp(91) open: vmk_MgmtUserInit error: 19
19:06:21:253306 [error] DeviceFinder_NVME.cpp(134) scanPhysicalDevices: Failed to connect to device. Ignoring intel-nvme2
19:06:21:253341 [error] Connection_Path.cpp(91) open: vmk_MgmtUserInit error: 19
19:06:21:253354 [error] DeviceFinder_NVME.cpp(134) scanPhysicalDevices: Failed to connect to device. Ignoring intel-nvme3
19:06:21:253389 [error] Connection_Path.cpp(91) open: vmk_MgmtUserInit error: 19
19:06:21:253402 [error] DeviceFinder_NVME.cpp(134) scanPhysicalDevices: Failed to connect to device. Ignoring intel-nvme4
19:06:21:253436 [error] Connection_Path.cpp(91) open: vmk_MgmtUserInit error: 19
19:06:21:253449 [error] DeviceFinder_NVME.cpp(134) scanPhysicalDevices: Failed to connect to device. Ignoring intel-nvme5
19:06:21:253483 [error] Connection_Path.cpp(91) open: vmk_MgmtUserInit error: 19
19:06:21:253497 [error] DeviceFinder_NVME.cpp(134) scanPhysicalDevices: Failed to connect to device. Ignoring intel-nvme6
19:06:21:253531 [error] Connection_Path.cpp(91) open: vmk_MgmtUserInit error: 19
19:06:21:253544 [error] DeviceFinder_NVME.cpp(134) scanPhysicalDevices: Failed to connect to device. Ignoring intel-nvme7
19:06:21:253578 [error] Connection_Path.cpp(91) open: vmk_MgmtUserInit error: 19
19:06:21:253591 [error] DeviceFinder_NVME.cpp(134) scanPhysicalDevices: Failed to connect to device. Ignoring intel-nvme8
19:06:21:253625 [error] Connection_Path.cpp(91) open: vmk_MgmtUserInit error: 19
19:06:21:253638 [error] DeviceFinder_NVME.cpp(134) scanPhysicalDevices: Failed to connect to device. Ignoring intel-nvme9
19:06:21:253672 [error] Connection_Path.cpp(91) open: vmk_MgmtUserInit error: 19
19:06:21:253686 [error] DeviceFinder_NVME.cpp(134) scanPhysicalDevices: Failed to connect to device. Ignoring intel-nvme10
19:06:21:253720 [error] Connection_Path.cpp(91) open: vmk_MgmtUserInit error: 19
19:06:21:253733 [error] DeviceFinder_NVME.cpp(134) scanPhysicalDevices: Failed to connect to device. Ignoring intel-nvme11
19:06:21:253767 [error] Connection_Path.cpp(91) open: vmk_MgmtUserInit error: 19
19:06:21:253780 [error] DeviceFinder_NVME.cpp(134) scanPhysicalDevices: Failed to connect to device. Ignoring intel-nvme12
19:06:21:253814 [error] Connection_Path.cpp(91) open: vmk_MgmtUserInit error: 19
19:06:21:253827 [error] DeviceFinder_NVME.cpp(134) scanPhysicalDevices: Failed to connect to device. Ignoring intel-nvme13
19:06:21:253861 [error] Connection_Path.cpp(91) open: vmk_MgmtUserInit error: 19
19:06:21:253874 [error] DeviceFinder_NVME.cpp(134) scanPhysicalDevices: Failed to connect to device. Ignoring intel-nvme14
19:06:21:253908 [error] Connection_Path.cpp(91) open: vmk_MgmtUserInit error: 19
19:06:21:253922 [error] DeviceFinder_NVME.cpp(134) scanPhysicalDevices: Failed to connect to device. Ignoring intel-nvme15
19:06:21:253956 [error] Connection_Path.cpp(91) open: vmk_MgmtUserInit error: 19
19:06:21:253969 [error] DeviceFinder_NVME.cpp(134) scanPhysicalDevices: Failed to connect to device. Ignoring intel-nvme16
19:06:21:254003 [error] Connection_Path.cpp(91) open: vmk_MgmtUserInit error: 19
19:06:21:254016 [error] DeviceFinder_NVME.cpp(134) scanPhysicalDevices: Failed to connect to device. Ignoring intel-nvme17
19:06:21:254050 [error] Connection_Path.cpp(91) open: vmk_MgmtUserInit error: 19
19:06:21:254063 [error] DeviceFinder_NVME.cpp(134) scanPhysicalDevices: Failed to connect to device. Ignoring intel-nvme18
19:06:21:254097 [error] Connection_Path.cpp(91) open: vmk_MgmtUserInit error: 19
19:06:21:254110 [error] DeviceFinder_NVME.cpp(134) scanPhysicalDevices: Failed to connect to device. Ignoring intel-nvme19
19:06:21:254144 [error] Connection_Path.cpp(91) open: vmk_MgmtUserInit error: 19
19:06:21:254157 [error] DeviceFinder_NVME.cpp(134) scanPhysicalDevices: Failed to connect to device. Ignoring intel-nvme20
19:06:21:254195 [error] Connection_Path.cpp(91) open: vmk_MgmtUserInit error: 19
19:06:21:254209 [error] DeviceFinder_NVME.cpp(134) scanPhysicalDevices: Failed to connect to device. Ignoring intel-nvme21
19:06:21:254244 [error] Connection_Path.cpp(91) open: vmk_MgmtUserInit error: 19
19:06:21:254257 [error] DeviceFinder_NVME.cpp(134) scanPhysicalDevices: Failed to connect to device. Ignoring intel-nvme22
19:06:21:254291 [error] Connection_Path.cpp(91) open: vmk_MgmtUserInit error: 19
19:06:21:254304 [error] DeviceFinder_NVME.cpp(134) scanPhysicalDevices: Failed to connect to device. Ignoring intel-nvme23
19:06:21:254338 [error] Connection_Path.cpp(91) open: vmk_MgmtUserInit error: 19
19:06:21:254351 [error] DeviceFinder_NVME.cpp(134) scanPhysicalDevices: Failed to connect to device. Ignoring intel-nvme24
19:06:21:254386 [error] Connection_Path.cpp(91) open: vmk_MgmtUserInit error: 19
19:06:21:254399 [error] DeviceFinder_NVME.cpp(134) scanPhysicalDevices: Failed to connect to device. Ignoring intel-nvme25
19:06:21:254432 [error] Connection_Path.cpp(91) open: vmk_MgmtUserInit error: 19
19:06:21:254446 [error] DeviceFinder_NVME.cpp(134) scanPhysicalDevices: Failed to connect to device. Ignoring intel-nvme26
19:06:21:254480 [error] Connection_Path.cpp(91) open: vmk_MgmtUserInit error: 19
19:06:21:254493 [error] DeviceFinder_NVME.cpp(134) scanPhysicalDevices: Failed to connect to device. Ignoring intel-nvme27
19:06:21:254526 [error] Connection_Path.cpp(91) open: vmk_MgmtUserInit error: 19
19:06:21:254539 [error] DeviceFinder_NVME.cpp(134) scanPhysicalDevices: Failed to connect to device. Ignoring intel-nvme28
19:06:21:254573 [error] Connection_Path.cpp(91) open: vmk_MgmtUserInit error: 19
19:06:21:254586 [error] DeviceFinder_NVME.cpp(134) scanPhysicalDevices: Failed to connect to device. Ignoring intel-nvme29
19:06:21:254620 [error] Connection_Path.cpp(91) open: vmk_MgmtUserInit error: 19
19:06:21:254633 [error] DeviceFinder_NVME.cpp(134) scanPhysicalDevices: Failed to connect to device. Ignoring intel-nvme30
19:06:21:254667 [error] Connection_Path.cpp(91) open: vmk_MgmtUserInit error: 19
19:06:21:254680 [error] DeviceFinder_NVME.cpp(134) scanPhysicalDevices: Failed to connect to device. Ignoring intel-nvme31
19:06:21:254714 [error] Connection_Path.cpp(91) open: vmk_MgmtUserInit error: 19
19:06:21:254727 [error] DeviceFinder_NVME.cpp(...
Hi Sptta,
Thanks for the pictures and the information provided.
We would further investigate on this, we will keep you posted with any updates.
Junior M.
DStor
SO I don't want to coopt this thread but I think i have the same issue.. so hopefully it can shes some light.
I have Vmware esxi 6.0 and 6.5 running p3700 NVMe drives in dell r730xd servers and non of them report back and the log looks just like Sptta's logfile.... ( tool version 3.0.4.400 )
as a side note a p3700 bougth in the same lot( so same firmeware in theory) in a different dell server ( r720) reports just fine with the same tool version on esx 6.0
Derek
Hi Sptta,
We would like to inform you that the latest version of the https://downloadcenter.intel.com/download/27248/Intel-SSD-Data-Center-Tool?product=87278 Intel® SSD Data Center Tool(3.0.9)
has been released.
We recommend you to perform a fresh installation of the VMware* ESXi 6.5 and try with the latest version of the Intel® SSD Data Center Tool.
Please let us know if you have the same results.
Junior M.
DStor
Intel,
I tried the newest version 3.09 on my esxi 6.5 install on a Dell R730xd and the logs looks the same and it reports "no results" exact same behavior as all the older versions....
Derek
Hi Derek1234,
Could you please provide us the logs of the file?
Junior M.
