Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
SSD Data Migration software doesn't recognize Intel SSD Series 535 on Windows 10 Pro system
I'm unable to migrate data to my new Intel SSD 535 Series (480 GB) - the Intel SSD is not recognized as being connected to my Windows 10 Pro 64-bit laptop. I've tried two different SATA-USB connectors that work with all the HDDs I've tried (2.5" and 3.5"). Laptop is a Toshiba Satellite A665-S5179 with Intel Core i5 CPU (M 480). I've removed all other USB devices from system. When I look at Disk Drives in the Device Manager it shows up as ASMT 2015 USB Device, not Intel SSD. Is this a known issue with the Windows 10 Pro and this Intel SSD? Is there a software or firmware fix in the works?
Tags (1)
Community Manager
That was a typo (the downfall of not having my USB keyboard attached). The correct device for the USB-SATA connector is ASMT 2105 USB Device.
