Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
SSD Optimizer Error in Windows 7 x64 Latest Firmware/Software
I updated the firmware on my 160gig x25-m G2 drive to the latest. I then installed windows 7 x 64 from scratch on an intel DP55kg motherboard.
When I run the toolkit 1.2 and scan the drive everything is OK. When I go to the tools to optimize the drive it gives me "Intel SSD Optimizer Error" with no other explanation.
I have tried chaning the ACHI drivers from Intels to Windows but that did not fix the issue. I have also turned off the scheduled defrag (which you should always do for SSD drives) and I turned off windows restore. It still does not fix the issue.
Tags (2)
Community Manager
If you are using the default msahci driver in AHCI mode, you do not have to run the Optimizer, the TRIM function is automatic.
Community Manager
The error happens with both the Windows and the Intel drivers. If you are using the windows drivers (which turns on TRIM) people have still found that running the toolkit works and makes a difference. So this still is an issue.
Community Manager
I have run benchmark tests both ways, using optimizer and not using optimizer--no difference for me. You do not have to run optimizer with AHCI mode and msahci driver in Windows 7.
Try reinstalling Toolbox. Do you have the latest firmware, 2CV102HD?
Community Manager
Yes I have the latest firmware. I just reinstalled the toolbox, but still the same issue.
Community Manager
Check that the drive is connected to one of the chipset SATA ports. Looks like these are supposed to be colored black on your board. According to some, connecting to port 0 or 1 may be preferable.
Community Manager
The drive is in SATA port 0.
Does Intel have a debug option or dump file for it's toolkit so you can figure out what is causing it to give an error?
Community Manager
SSD Toolbox has an Export button option to export log files.
Community Manager
The export option creates a CSV file with the drive's information. It does not contain any errors from the management tool.
Of interest I find that when I go to run the management tool for my drive it gets to 7% before it gives me the dreaded Intel SSD Optimizer Error
Community Manager
I had very similar problem:
SSD: 80GB x25-m with the latest 02HD firmware
OS: Windows 7 Home Premium 64bit
MB: Gigabyte GA-P35-DS4
SSD connected to channel 0 SATA port
SATA running in AHCI mode using msahci.sys
When I ran Intel SSD Optimizer, it immediately failed with "Intel SSD Optimizer Error" message.
Solution:
I've found that the problem was caused by TrueCrypt (using the latest version 6.3a). I don't have any part of SSD encrypted, but I had mounted 1TB encrypted partition. After I dismounted this encrypted drive and shut down TrueCrypt completely, SSD Optimizer started working like a charm (I know that it is not necessary to use SSD Toolbox to trim the drive when using msahci.sys, but I wanted to try it).
Community Manager
Thank you. You solved my problem. I am using PGP to create an encrypted drive which resides as a file on the SSD. Once I removed PGP everything worked.
Community Manager
You're welcome! I'm glad that this helped.
It seems that the Toolbox has problems running with other mounted virtual drives...
Community Manager
I am experiencing the same error as the OP. I'm running W7-64, my drive's firmware has been upgraded (ver 2CV102HD), it's configured as AHCI device on SATA Port 0 on an EVGA X58 motherboard.
My write performance has started to slip, so I installed the latest version of the Optimizer (twice). Unfortunately, I'm getting the same error.
I've removed all other hard drives and exited from any applications that I think might look like a mount point (Logmein, WHS Connector, Windows Live Sync).
Any thoughts and suggestions would be appreciated.
*** UPDATE ***
After totally removing MS Office 2010 Beta (Click and Run version) the optimizer works!
Community Manager
is that so. it's hard to believe the ms office application can come in conflict with optimizer. have u tried other ms office versions?
Community Manager
If you use the msahci.sys driver, you don't need to run the optimizer, assuming you are not doing RAID.
Community Manager
@ichun: I'm successfully running Office 2007 Pro with no problems. I intend to install Office 2010 Beta using the standard installation process. I think the virtualization software built into the 'Click to Run' software is causing the problem. It would be interesting to find out if anyone else using products based the former 'Softricity' platform experience similar problems.
@ambizytl: I know I shouldn't need to use the optimizer. Now that I've removed the virtualized Office 2010 product, I plan to monitor performance (without using the optimizer). If performance doesn't degrade, I don't plan on using the optimizer again. I will update this forum with my thoughts...
Community Manager
Hi
I have the same issue as the original poster, and i can't get the SSD Optimizer to work. When i click the "run" button the whole bar turns red and the status changes to "failed" and Recommended Action changes to "Intel SSD Optimizer error".
I've disabled defrag, turned on ACHI, i have no virtual drives, no encrypted areas, the firmware is 02HA and i've tried with both version 1.2 and 1.3 of the SSD Toolbox.
And i can run the diagnostic scans in the toolbox without any errors.
Any more tips and tricks for that issue except the ones that have been discussed so far?
Gigabyte X58A-UD7
I7 930
160gb x-25-m G2
Win7 Ultimate x64
