Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
SSD Toolbox 3.1.2 Results
When I run the SSD Toolbox from the command line at the end is "Result: # ". What are the result numbers? Where would I be able to find a list for Result codes? I think that "Result: 0" is when the command completed successfully., When I run "-config defrag" I get "Result: 89," and when I run "-config dipm" I get "Result: 90". Did those fail? Is there documentation for this?
Tags (2)
KenF_Intel
Hi Tim ar,
I'm trying to track this information down. I'll let you know when I get the list of result codes.
