I need to erase an ssd to return under warranty. Does the latest version (3.5.10) of the Intel SSD Toolbox "Secure Erase" work with Windows 10? Seems to secure erase in my case - but I'm having trouble with the toolbox identifying my drive correctly. So, I don't know whether the toolbox now works with Windows 10 or is in error (toolbox notes indicate secure erase only works with Windows 7).
Latest version of toolbox is 3.5.11. According to release notes, it has had Windows 10 support for a long while (since v3.3.7, Sept. 2016).
Thanks for the taking the time to reply. The latest toolbox you mentioned (3.5.11) was apparently just released this evening but still has the same note as the previous toolbox.
"NOTE: Secure Erase functionality for SATA devices is blocked by the Windows 8, Windows 8.1 and Windows 10 operating systems."
https://downloadcenter.intel.com/download/28808/Intel-Solid-State-Drive-Toolbox?v=t
https://downloadcenter.intel.com/download/28674/Intel-Solid-State-Drive-Toolbox
I don't see any mention of Windows 10 with secure erase in the pdf release note for the version (3.3.7) you mentioned. 3.3.7 description relates to updating the secure erase command for the intel 750 SSD and a mention of a fix for Windows 10 with Marvel RAID. Maybe I missed something and support was added in that version - but not listed specifically in the pdf.
https://downloadmirror.intel.com/28808/eng/Intel_SSD_Toolbox_3_5_11_Release_Notes_325993-051.pdf
I really just wanted a second opinion of someone who's used it with Windows 10. Thank you for letting me know.
What is the OS limitation that prevents Windows 10 from being used? The toolbox doesn't display any difference between 7 and 10 - both indicate a successful erase.
Thanks for providing an answer and confirming the need for Windows 7. Not sure if any Intel software engineers read the forums, but the tool shouldn't show a successful erase if that's not the case - that's bad software design (i.e. false positive). Also, those "low level" formatting programs are mostly designed for hard drives and also don't erase bad blocks or bad ssd nand cells, like a secure erase would. That's also assuming either those recommended low level formatting tools virtualize the nand storage space correctly or the intel ssd controller does.
TL:TR for anyone reading this - use SSD Toolbox or Data Center Tool with Windows 7, nothing else works for business and legal compliance.
For more complete information about compiler optimizations, see our Optimization Notice.
