Solid State Drives
Support for Issues Related to Intel® Solid State Drives
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
4366 Discussions
SSD Toolbox: ANALYZER.EXE has begun crashing when trimming
Community Manager
I have used SSD toolbox 3.0.1 with my X25 G2 120 Gb for a long time, manually running the trim/optimization command (not scheduled) about every week or so. For at least six months this has worked fine, and for longer if we include previous versions of the SSD toolbox. But since yesterday the program crashes whenever I try to run the optimization. I have since updated to version 3.0.5 of the toolbox but no change.
It says analyzer.exe has stopped working and then there is a bug report as per below. Any ideas what is going on here? I don't think I have installed or updated anything since the last time I successfully ran the optimization.
Actually what it does is: I click the RUN-button to initiate optimization, whereupon the warning dialog pops up and there I click START. The program advances to 34% and stops there for a while as it always has. But instead of finishing after a few seconds the Windows error message appear on screen. When I click away that message I get the "100% Command finished" successfully displayed in the optimizer. So the program tells me it worked but it, or rather one of its modules, has also crashed in the meantime. So how can I trust that 100% message?
I am using Windows 7 ultimate 64-bit. Actually, thinking about it I *may* have updated the OS to SP1 since the last time I successfully ran the optimizer.
Problem signature:
Problem Event Name: APPCRASH
Application Name: Analyzer.exe
Application Version: 0.0.0.0
Application Timestamp: 4d49ee6f
Fault Module Name: MSVCR90.dll
Fault Module Version: 9.0.30729.4940
Fault Module Timestamp: 4ca2e32e
Exception Code: 40000015
Exception Offset: 0000000000042686
OS Version: 6.1.7601.2.1.0.256.1
Locale ID: 1053
Additional Information 1: 8586
Additional Information 2: 85862f9a9036c801e4351e5225d8eb67
Additional Information 3: 6e9d
Additional Information 4: 6e9d93608b54911b9e696bc7fc3e59b8
