Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
SSD Toolbox crashes after system migration
I have an HP win 8.1 system running a stripe set of 530 240 Gig SSD. SSD Toolbox worked fine when there was only one drive but I added a second one and set it up in Raid 0. After migrating the OS to the new stripped volume on the Intel Rapid Storage RAID, SSD Toolbox crashes every time. I tried to reinstall it but it still crashes. I'd like to run this program to keep rack of the drives age.
Kevin_M_Intel
I would like to get more information about the system you have.
Please provide the following:
  1. What is your computer model number?
  2. What SATA chipset are you using to connect the SSDs?
Kevin M
DChan28
Your Second Drive might be defective, but need more information to come to a conclusion though
ASouz7
Hello GedLee,
Could please try this drive in a different computer to see if the same thing happens. Please make sure this drive is running the latest firmware version.
Use our Intel® SATA Solid-State Drive Firmware Update Tool and check if there is any update to its firmware. use this link to lead you to our Intel® SATA Solid-State Drive Firmware Update Tool found in our download center. https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=18363 Intel® Download Center
Let us know as soon as possible if this helped you.
