Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
SSD X25-M 160GB Clone Operation rendered SSD unusable
I was cloning my standard HDD to my SSD (X25 160GB Gen 1) using Acronis, when power save settings shut the laptop down in mid clone. Since then, I can't get the SSD to register as a valid drive. Is there a way of recovering the drive (flashing an SSD image, etc.)? I'm at a loss as to what to do.
Cheers.
Tags (1)
Community Manager
How were you cloning (i.e. USB HDD applying image to internal SSD)?
When you say "can't get the SSD to register as a valid drive".... is that in Acronis or BIOS? Is the SSD connected via the internal SATA port? If so, does the BIOS register the drive?
You may just need a low-level reformat and start again.
Community Manager
The SSD was in an external USB enclosure, and I was cloning my laptops internal HDD using Acronis True Image Home Version 2011.
When I plugin the SSD (still in the USB enclosure) into the laptop, it is not recognised by Windows Drive Manager, or File Explorer (hence I can't refomat, etc.). When I look at the System Device Manager, it appears that the drive is 'seen', however I'm unable to do anything. Acronis is also unable to recognise that the SSD is attached.
I haven't tried inserting the drive internally to see if the BIOS would recognise and enable reformatting. Is this worth a go?
Community Manager
I've recently had a strange experience with a brand new X25-M (my second now). I had a driver error that caused a conflict in sleep mode. This caused a blue screen when the PC came out of sleep mode. The drive came up as "locked" in the raid rom (it was a non-array member disk at the time) and when I tried to reboot the drive could not then be seen by the OS. (Win 7/64).
I tried hddease and had problems getting it it to run with the drive attached but eventually I was able to get in running and execute a secure erase. The drive became un-locked and has worked perfectly ever since. Weird. Luckily I was working with a recent system image so I didn't lose any data.
Community Manager
If Windows sees it, then it will appear in the BIOS. You might want to try a low-level reformat or zero-write to it.
Community Manager
Hi Redux - How did you know that your drive was in a 'locked' state?
Community Manager
I assume to do this, you need to insert the drive within the laptop?
Cheers.
Community Manager
That is what it told me in the Raid ROM when I tried to boot. Whilst the drive was in this state I could not boot up with it plugged in. When I hot plugged it after Windows had loaded the drive could not be detected. To be able to secure erase the drive I had to leave it un-plugged until hdderase had loaded past a certain point. Totally weird. I've used Intel drives for a couple of years and this was the 1st time I experienced something like this.
Running a secure erase with hdderase resets the drive back to factory condition.
Community Manager
Thanks for explaining. I'll have a go this evening at using HDDErase. Failing that, I'll pop the SSD within the laptop to see if the BIOS can recognise and force a low level format.
Fingers crossed!!
