cancel
Showing results for
Search instead for
Did you mean:
SSD X25-M 80GB with only 8MEGAbytes available
Esteemed Contributor III
A few days ago I bought an Acer Aspire Timeline AS3810t-6775 which came with an Intel SSD X25-M 80GB. After 2 days of operation, the HD simply recognizes only 8 megabytes. In the BIOS, Serial Number field is shown BAD_CTX. I wonder if Intel has a fix for this problem. I can not claim warranty as bought in the U.S. but I am in Brazil now.
11 REPLIES 11
I thought Acer has international warranty?
try calling Intel for the RMA then....
Hello everybody. After using the hdderase 3.3, the active HDAT2 kill to try to restore the factory image of my HDD, I have not had success. The problem persists! I came in contact with Intel and told me to look with Acer. I did but Acer has asked me to send the laptop to get the warranty, this is out of the question because I'm in Brazil. Anyway, I hope that some tool from Intel yet to be released to correct this problem. I've changed the HDD from my laptop and everything works perfectly.
After erasing with hdderase 3.3 did you get you capacity back or not? Or it still "8MEGAbytes available"?
I've used victoria tool also (http://www.google.ru/search?hl=en&newwindow=1&q=victoria+windows&aq=f&oq=victoria+window http://www.google.ru/search?hl=en&newwindow=1&q=victoria+windows&aq=f&oq=victoria+window) to erase drive with test write function (multipass about 48 hours). But after hdderase I got my capacity back.
If you can provide more information, then do it, please.
