Community
cancel
Showing results for
Search instead for
Did you mean:
FEide
SSD X25-M shows only unformatted 8MB Storage
Hey all,
as I didnt use my SSD X25-M for almost 1 year, I wanted to use a USB Adapter Kable for Using my SSD as External Storage.
First the SSD woked fine, haveing 4 Partitions (I dont remember exactly how it was configured). After formatting 1 Partition and filling it with data, I switched the "external SSD" to another Computer the get all the pictures. During that my Systempartition (Win7 from a third Computer) crashed. Windows asked me to format the partition to use it. I thought it could be a Problem with the USB Adapter Cable and connected the SSD with an SATAII Cable from the Computer. Now all Partitions moved away and instead I see a 8MB unformatted Storage in the Discmanagementsystem from Windows 7.
I really dont care about the Data on the SSD but I wish I could reactivate the SSD for using itsStorage.
Do you have any idea or tooltip for solve this problem?
I already tried to use the SSD on a Computer with win7 and a Tablet PC with win8.1
Here you have a AIDA64 log from the SSD
[ INTEL SSDSA2M080G2GN (BAD_CTX CD1FAF05Ì) ]
ATA Device Properties:
Model ID INTEL SSDSA2M080G2GN
Serial Number BAD_CTX CD1FAF05Ì
Revision 2CV102HA
World Wide Name 5-001517-9591A909C
Device Type SATA-II @ Oxford
Parameters 16383 cylinders, 16 heads, 63 sectors per track, 512 bytes per sector
LBA Sectors 16384
Physical / Logical Sector Size 512 bytes / 512 bytes
Multiple Sectors 16
Max. PIO Transfer Mode PIO 4
Max. MWDMA Transfer Mode MWDMA 2
Max. UDMA Transfer Mode UDMA 6
Active UDMA Transfer Mode UDMA 6
Unformatted Capacity 8 MB
Rotational Speed SSD
ATA Standard ATA/ATAPI-7
ATA Device Features:
48-bit LBA Supported, Enabled
Automatic Acoustic Management (AAM) Not Supported
Device Configuration Overlay (DCO) Supported, Enabled
DMA Setup Auto-Activate Not Supported
Free-Fall Control Not Supported
General Purpose Logging (GPL) Supported, Enabled
Hardware Feature Control Not Supported
Host Protected Area (HPA) Supported, Enabled
HPA Security Extensions Supported, Disabled
Hybrid Information Feature Not Supported
In-Order Data Delivery Not Supported
Native Command Queuing (NCQ) Not Supported
NCQ Autosense Not Supported
NCQ Priority Information Not Supported
NCQ Queue Management Command Not Supported
NCQ Streaming Not Supported
Phy Event Counters Supported
Read Look-Ahead Supported, Enabled
Release Interrupt Not Supported
Security Mode Supported, Disabled
Sense Data Reporting (SDR) Not Supported
Service Interrupt Not Supported
SMART Not Supported
SMART Error Logging Not Supported
SMART Self-Test Not Supported
Software Settings Preservation (SSP) Supported, Enabled
Tagged Command Queuing (TCQ) Supported
Write Cache Supported, Enabled
Write-Read-Verify Not Supported
SSD Features:
Data Set Management Supported
Deterministic Read After TRIM Supported
TRIM Command Supported
Power Management Features:
Advanced Power Management Not Supported
Automatic Partial to Slumber Transitions (APST) Disabled
Device Initiated Interface Power Management (DIPM) Not Supported
Device Sleep (DEVSLP) Not Supported
Extended Power Conditions (EPC) Not Supported
Host Initiated Interface Power Management (HIPM) Not Supported
IDLE IMMEDIATE With UNLOAD FEATURE Supported, Enabled
Link Power State Device Sleep Not Supported
Power Management Supported, Enabled
Power-Up In Standby (PUIS) Not Supported
ATA Commands:
DEVICE RESET Not Supported
DOWNLOAD MICROCODE Supported, Enabled
FLUSH CACHE Supported, Enabled
FLUSH CACHE EXT Supported, Enabled
NOP Supported, Enabled
READ BUFFER Supported, Enabled
WRITE BUFFER Supported, Enabled
ATA Device Physical Info:
Manufacturer Intel
SSD Family X25-M (34nm)
Family Code Name Postville
Form Factor 2.5"
Formatted Capacity 80 GB
Controller Type Intel PC29AS21BA0
Flash Memory Type Intel 34nm MLC NAND
Physical Dimensions 100.45 x 69.85 x 7 mm
Max. Weight 76 g
Max. Sequential Read Speed 250 MB/s
Max. Sequential Write Speed 70 MB/s
Max. Random 4 KB Read 35000 IOPS
Max. Random 4 KB Write 6600 IOPS
Interface SATA-II
Interface Data Rate 300 MB/s
Buffer Size 32 MB
ATA Device Manufacturer:
Company Name Intel Corporation
Product Information <a class="jive-link-external-small" hre...
jbenavides
Hello Yngvar,
The condition you describe normally indicates that he drive has failed. We strongly advise you to http://www.intel.com/p/en_US/support/contactsupport Contact Support for further assistance.
As last option, you might want to try updating the firmware with the https://downloadcenter.intel.com/download/18363/Intel-Solid-State-Drive-Firmware-Update-Tool Intel® Solid-State Drive Firmware Update Tool orhttps://downloadcenter.intel.com/download/18455/Intel-Solid-State-Drive-Toolbox Intel® Solid-State Drive Toolbox. If the issue persists after this, please engage your nearest support center.
FEide
Hey Jonathan,
answering in the same time! ;-)
I will try to make a firmware update, in SSD Toolbox its not possible but i will get the firmwareupdate tool you posted.
FEide
Ok, the problem is solved. But I dont know how...
I tried to make the firmwareupdate with the bootable iso useing easyBCD.
When I ran the update in The Firmware Update Tool I got a Errormessage:
The [...] Update did not complete. Please try the following:
1. Dis. drive password in BIOS and retry
2. Enable SMART in BIOS and retry
3.Enable Legacy IDE mode in BIOS and retry
If you need further assistance contact [...]
After I got back to the menu to start the update, the Firmware Version was still the old.
I tried once more, failed.
Went into BIOS:
1. No Drivepassword active.
2. SMART generally enabled but in the informations for the SSD it's disabled and i can not enable it inside there (just in another menu point)
3. Found something like the IDE but it sound like it's a kind of other option so I didnt touch it.
I left the BIOS w/o saveing and started Windows.
I checked the Drivemanager from Windows and see, the 80GB of the disk is back.. unpartitionated. So I really dont know what happen at all to my SSD.
Is there a chance now to restore the files? Or lost?
Thanks for... yea I dont know? The right stuff in the right moment? Am I lucky or what...
Cheers! Yngvar
PS I got the "logfile" of Intel SSD Toolbox when the SSD did not work and from right now, gonna add it here
Before:
http://noplacewedratherbe.synology.me/SSD/ssd.csv http://noplacewedratherbe.synology.me/SSD/ssd.csv
After:
http://noplacewedratherbe.synology.me/SSD/ssd2.csv http://noplacewedratherbe.synology.me/SSD/ssd2.csv
jbenavides
Hello Yngvar,
I am glad that your drive is working again. The data in the log seems to be OK, however, it still shows some abnormal information consequence of the 8 MB problem.
Please keep in mind that this condition may reoccur, so if you are able to use the SSD, it would be recommended to make sure the data is backed up. If the drive is showing empty and unpartitioned, it may not be possible to recover the data.
FEide
Hey Jonathan,
I had a phone call with the German support Team. They couldn't tell me what I didnt know yet.
The problem right now is, that I can not iniciate a MBR or GUID on the SSD. I tried "s0kill" but the programm can't do anything, not even read the first row. (And I am not sure if something like that physically exists on a SSD...). I am out of ideas.. Maybe I try partition magic or another programm...
jbenavides
Hello Yngvar,
I am sorry to hear that the issue persists. As I mentioned before, this condition normally indicates drive failure and may not be recovered. If the options you are planning do not work, it would be advised to http://www.intel.com/p/en_US/support/contactsupport Contact Support and engage your nearest support center.
FEide
Well I maybe found the problem but I dont have a solution yet.
In the Computer I am used to use the SSD is a Gigabyte GA-x58A-UD7 Board with Xenon W3520 Intel Processor.
In another form i read that a Samsung HDD had the same problem and they said it occures of the Gigabyte "Dual BIOS" that saves a copy of the BIOS in the HDD/SSD.
I tried to find the SSD with the Intel SSD Toolbox but couldnt find my SSD, just not showing it.
So I tried the Samsung Magician and wow, this tools shows the SSD, i switched back to the Intel SSD Toolbox and it shows it too now, but only with 8MB and no partitions. The Tool does not have any setting to search for failurs. The fast and advanced scans are not possible because "it has no partition".
I have the full DriveInformation from the Intel SSD Toolbox but I can not copy/paste it from the table.... If you need something from inside, let me know.
Also the erase mode says that the SSD is in "Security Frozen" Mode. To switch the mode, take off the energy plug and insert after a few seconds, but nothing happens
some screens:
