Community
cancel
Showing results for
Search instead for
Did you mean:
JBere
SSD bloqueado
Boa noite, SSD após trocar de notebook, esta pedindo senha assim que ligo o notebook, porem nunca coloquei senha na bios nem no hd...
ja tentei diversas senhas mas não deu certo, como faço para resolver isso?
SSD Pro 2500 series 240GB
Community Manager
Hi Nightwallk,
As per our translator tool, We understand that the Intel® SSD Pro 2500 Series is asking for a password.
It seems that someone else had set up a password for the SSD at BIOS level. The only way for you to access the SSD is with that information.
If you forgot the password there is no way to avoid the security that the SSD has.
We suggest you contact the person that had set up this password. Otherwise, you will not be able to access the SSD.
Junior M.
