cancel
Showing results for
Search instead for
Did you mean:
SSD compatibility
Sonny
New Contributor
Question:  Is the Intel SSDPEKNW010T8X1 the same as SSDPEKNW010T8H, and/or is it a direct replacement?
1 ACCEPTED SOLUTION
JosafathB_Intel
Valued Contributor
Hello, Sonny.
Thank you for contacting Intel® Memory and Storage support.
As we understand, you are requesting information regarding the Intel® SSD 660p Series (1.0TB). If we inferred correctly, we would appreciate it if you may review the following information:
The SSD ordering code SSDPEKNW010T8X1 refers to the Intel® SSD 660p Series (1.0TB, M.2 80mm PCIe 3.0 x4, 3D2, QLC) generic.
The SSD ordering code SSDPEKNW010T8H refers to the HP modified version of the Intel® SSD 660p Series.
There are several versions of this OEM (original equipment manufacturer) version of 660p, and after the letter, H will include a letter or a number to differentiate them.
In case you are interested in those HP* modified drives. We advise you to contact HP* to get assistance regarding the firmware versions, features, and other modifications that these drives may include.
To answer your question:
No, the different ordering codes you shared are the same SSD model, but some of them have specific firmware and features added by HP*.
We hope you find this information helpful. Please let us know if you need further assistance.
We will follow up with you again on Friday, the 26th of November 2021, if we do not receive an answer from you. Please, let us know if you would like to schedule a different date for the follow-up.
Best regards.
Jos B.
Intel® Customer Support Technician.
2 REPLIES 2
JosafathB_Intel
Valued Contributor
Hello, Sonny.
Best regards.
Jos B.
JosafathB_Intel
Valued Contributor
Hello, Sonny.
Greetings from; Intel® Memory and Storage support.
We were reviewing your community thread, which is related to the Intel® SSD 660p Series. We would like to know if you were able to check the information we shared in our previous post.
We will follow up with you again on Tuesday, the 30th of November 2021, if we do not receive an answer from you. Please, let us know if you would like to schedule a different date for the follow-up.
Best regards.
Jos B.
