Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
SSD damaged after 1day ?
i have installed Win7 64bit 3 times on 3 different SSD´s (all of them are X25-M G2 80GB 2.5")
The fist one worked for 1 day before my System reported a S.M.A.R.T. Error (something with the end-to-end error correction)
the Serial Number was : CVPO051301QK080JGN. I sent it back to the supplier for an replacement as i thought this can happen.
The 2nd one worked for about 20 days and then reported the same Error as the 1st one (Serial Number was : CVPo102500Z0080JGN) . I was really surprised as i was quite happy with the performance, so i sent it back to the supplier for an replacement, ok all good things are 3 i thought. But the supplier sent me back the money.
So i ordered a new one from a other supplier, i installed again the Win7 64bit and was stilll working with all windows updates, when suddently the system keep freezing all 2-3 seconds for 1 second, first i thought it is based on the updates which get installed, but finnaly the system freezed completely and i did a hard power off.
The reboot started but what that.... no SSD anymore ??? it does not appear in the BIOS. So now also the 3rd SSD has obviously the same issue, I´m really irritated as all research i did before told me that this is the SSD to use. I have also ordered a new SATA Cable which did not make any difference.
Now i sent back also the 3rd SSD (X25-M G2 80GB 2.5") and will wait for anybody who can tell me whats going wrong on my end :-) my current system is not the newest but runs stabel for 2 years and i had never issues with it but i assume it don´t like intels SSD´s :-)
System :
Mainboard : ASUS P5N-E SLI (NVIDIA nForce Controller)
Grafik : NVIDIA GeForce8800 GTX
Did anybode fight with the same issues i have ?
I think i will just stay on my old HDD and put the Money in my new bicycle :-)
cheers
Jens
Tags (1)
Community Manager
While possible, odds are you did not recieve three defective SSDs.
Did you use the same SATA cable each time? A bad cable can obviously cause issues.
Is the mobo BIOS updated and your SSD has the latest firmware?
Community Manager
yes i used the same SATA cable each time, the same SATA cabel which is working with my current HDD from WD with 80GB and which works also with the DVD-ROM drive. I have tried a new cable only with the 3rd SDD once the error already occured :-(
I just thinking to wait till the new 510 or 310 SDD´s from Intel are available and order those instead of trying one more of the X25.
Community Manager
I have four X25-M 80GB SSDs, and they all work perfectly, they are between a year and four months old.
But, there is a recent post in this forum about another X25-M 80GB SSD having the same SMART error as you mentioned. So, I'm wondering if there was a bad production run of these SSDs, since you purchased these recently, and you received ones from that possibly bad batch? This is the first time we've seen that error mentioned with this or any Intel SSD on this forum that I can recall, so having this problem posted twice in a very short interval has me wondering. Let me be clear, my statement is a theory based on two reports of this problem, which are the only basis for it, but it seems more than a coincidence, IMO.
The only other possiblility I can think of is checking the value of the 5V rail on your PS, since these SSDs only use 5 volt power, and if the rail was to high, it might cause problems.
Community Manager
Same problem here.
Though I am only on my second one.
I installed Win 7 64 bit, and it died after about a month. Sent it back to Intel for exchange.
In the meantime got another brand, installed Win 7 64 and running with no problem.
Got the replacement and tried to use it to install Win XP 32 and became a brick after first round of updates.
Will return it for a warranty replacement, again.
My Mobo Nvidia 680 SLI
Graphics Nvidia NForce 8800GTS.
Community Manager
NVIDIA say no more
Community Manager
Try disabling command queueing on the port the SSD is connected to. A friend of mine with an Intel SSD and Nvidia motherboard had to do that to get it to work properly.
Community Manager
Try Intel SSD firmware update FW version 02M3.
18 January 2011
2CV102M3
This firmware revision fixes enumeration and slow-boot issues on SATA 6Gb/s controllers, adds improvements to S.M.A.R.T. attributes for more accurate reporting of drive health, improves NCQ capability, and fixes possible drive hangs when reading S.M.A.R.T. self-test log.
Community Manager
Dissapointed here as well, my 80G intel 320 was only 2-3 days old when I reset the system because it froze up and the drive never worked ever since, it shows 8m capacity on the disk manager, cannot initialize, format or do anything with it.
I am running EVGA x58 i7 950 SLI GTX560ti 12Gram windows 7 home 64bit.
Tried installing it to another system but no use it's stuck on the 8m capacity ???????????? go figure
Community Manager
sogersortep, That does not sound good about your SSD. You can give the following a try if you'd like before returning it, which you should do now if there is a time limit to return it.
If you don't have the Intel SSD Toolbox on your EVGA X58 PC, download and install it. You should run either of the Diagnostic Scan's to see what the results are. In the Management Tools section, you should perform a Secure Erase, although you may need to format the drive first, and check the Help or Toolbox User Guide for more information if you need it.
If the Secure Erase completes fine, you can then try the SSD again, which will be starting over as if it is new, if it is not broken. But, if it is truly broken, then this will not fix it of course. You could also attempt a firmware update on it. If it seems fine after all of this, you could give it a chance and see how it goes, but returning it may be your best option.
Community Manager
Thanks for the reply, the only utility I ran was something called "crystaldiskinfo" that shows the current condition of the HDD's and in this case it showed on the SSD serial instead BAD_CTX god knows what that means, but it's probably something similar to a bad sector because the drive just felt like it due to low quality parts used in the drive.
I cannot explain it any other way, I don't abuse my equipment, and I hold Intel responsible 100% if you release a fast drive make sure you release the repair tools to go with it, otherwise don't release it because it would look like a rip off scheme more or less.
My 2 x 300G 10000rpm velociraptors run better than the SSD drives regardless the 5.9 windows experience level which is bullshit IMHO I think I'll go back to those until Intel finds a cure for that particular someone in their team with the SSD unilateral wet dream fiasco....and I know I am not the only one with the same issue here.
Community Manager
Community Manager
Would you be happening to use USB connection there?
Community Manager
No, I hooked it up to a SATA port on the mainboard to run the toolbox tests which when I click on the drive there are no options on the left side to click on, and when I click on any of the other drives it keeps refreshing the screen and cannot use any of the options anyway.
I ran the firmware disk (burned from the .iso) and it said that the drive already has the firmware installed
I also ran the tests with the USB bridge and returned the same results...now I'm really stuck
Community Manager
And besides the thing with the toolbox is weird, if you click on a drive it keeps refreshing the screen, all the buttons are grayed out and that's as far as I can get with the toolbox
Community Manager
Ok, if you got a broken SSD, that is frustrating and a PITA, but it doesn't mean they are all bad products and that you are being taken advantage of. I have several Intel SSDs, and they have all work fine for me, never the slightest glitch.
A couple questions for you regarding your PC's configuration. You have an X58 chipset mother board, so you have an Intel ICH10R SATA controller, which is considered one of if not the best chip of it's type. You also have two SATA 6Gb/s ports provided by the (dreaded) Marvell chipset, likely a 9128, used (and abused) on most X58 boards. You may have a defective SSD, but I must ask if you are using a Marvel SATA port with your SSD?
If so, you really need to try it on the Intel SATA ports. The Intel Toolbox won't work correctly with the Marvell chipset. The number of forum posts on any mother board manufactures web site about problems with the Marvell chipset are so huge compared to problems with any kind of SSD, there is no comparison. If you have used your SSD on the Intel SATA ports with the results you described, then you quite likely have a defective SSD which needs to be replaced.
Yes, your Velociraptors in RAID will easily outperform a broken SSD, that is easy to do. Hopefully you'll end up with a functioning SSD and enjoy it as much as I do mine.
Community Manager
I have the SSD hooked up on the 6G port, and it looks like it has thrown a rod permanently, I don't want to spend anymore time trying to revive it, so my next one will be a 120G SSD after I send it back, hopefully Intel will let me do the exchange.
Prior to the X58 installation I tried the drive on my older Nforce 780i SLI Evga and I had many freeze ups as well, that board uses a Northbridge chip if I am not mistaken, maybe it's Evga components the drives have a problem with.
The toolbox didn't run on that set up either with win 7 ultimate x64 8200 quad 2.6G cpu corsair DDR2 / Nforce 780i SLI / 2x 300G velociraptor WD 10000rpm
Community Manager
It might be easier/quicker to exchange your SSD with your retailer, but that is up to you.
Your NForce 780i mother board is another example of a non-Intel chipset mother board. That board, like an Intel X58 board, use what is generically termed a Northbridge and Southbridge chips that perform much of the work that the CPU cannot do. In that type of configuration, the SATA I/O functions are performed by the Southbridge chips, regardless of who makes them. On an X58 PC, the ICH10R chip is the Southbridge and performs among other things the SATA I/O duties.
It sounds like we are 99% sure your SSD is bad. It should have worked on the NForce board, given that it was not defective, although I doubt the Toolbox would function on that chipset, that does not surprise me at all.
If you haven't tried your SSD on the X58 board on the Intel SATA ports, it is worth a try. If that is your RAID interface, it makes no difference to the SSD or RAID, and the Toolbox should run in that configuration. That is actually an optimal configuration for an SSD, recommended by Intel. But that is up to you.
Community Manager
Thanks for all the input, I am going to give the SSD a last shot on the regular SATA ports of the x58 board although that set up cost me an arm and a leg to build and I don't want to fry anything by testing parts on it but it's worth a last try.
You seem to be pretty tech savy so what other boards would you recommend for SLI set ups on GTX 560ti i7 950 cpu (except MSI) that are more SSD friendly, I am pretty concerned about image and the way they look inside the Antec 900 SE more than performance, as long as they perform OK I'll consider them for future builds.
Naturally performance is important but I figured computing is more or less an eye candy hobby and if we have to spend too much time ressurecting bricked parts where's the fun ?
Community Manager
I really hope you try your SSD on the Intel SATA ports, that is the ultimate test, and if it doesn't work there, then it is defective.
Thanks for your comment, but I'm not a big gamer. I can offer some opinions that might help. One quick comment somewhat off your question, the new 2nd generation i7 Intel CPU's, or Sandy Bridge, use chipsets (H67, P67, Z68) that don't have many PCI-E lanes, fewer than 1st generation i7 CPU's (your i7-950, I have an i7-930) chipsets (X58). My point is you won't be gaining anything with gaming going to the current Sandy Bridge mother boards. The second PCI-E slot will always be limited to 8x speed, while the first will be at 16x.
I tend to like ASUS mother boards, as they tend to be performance oriented and are also have many made for gaming. If you will stay with an Intel SSD, I would be sure to get Intel chipsets on the board, as really any board made for i7 CPUs should have. For an Intel SSD, or any really, make sure they have the ICH10R chip, which is Intel's best desktop Southbridge-type chip, although it only has SATA 3Gb/s ports. The 'R' means it supports RAID, and even if you don't use that, it is worth having. You have that now BTW.
I understand why you have an EVGA board if you care about appearance, I have an EVGA X58 SLI LE, which is very sharp looking (it's in it's box right now! And EVGA has B-Stock available for less than $100!) ASUS does not have any X58 boards in black AFAIK, but check their site. Intel boards tend to be more conservative, but if you would like an illuminated skull image on your X58 board, they have it, in black too I believe. I've had good luck with Gigabyte boards too, but I haven't owned any of their current models.
If you have a Fry's store near you, they have all their mother boards on display, so you can get a better idea what they look like. Personally, I am waiting for the Intel socket 2011 CPUs and boards to appear, late this year or early next year. The CPU is larger than 1366 models, quad channel memory, at least 40 PCI-E lanes in it's chipset, boards for those should be real eye-candy. I would bet we'll see builds with three '590's on them, the water cooled versions would look so good.
I may lose my credibility with some other forum members after this post, but hey it's Saturday in June, le'ts party!
Community Manager
Well, somehow the toolbox worked on the x58 board after I installed some utility from Intel called "rapid storage technology" ran the tests on the SSD and all came out OK except of course the capacity which is still 8M (it's funny how computers operate-garbage in garbage out) I had enough of that drama, Monday morning it's going back to Intel (with a big sad face drawn on the plate ) and I'm getting a 120G
I still think that Intel should've taken care of this 8m business by releasing some sort of fix or patch for EVGA users, I'm sure it's no big deal to them, just an engineer or two spending a weekend typing codes on a computer getting overtime.
Why I went with EVGA ??? ....I'm not sure, I guess it was image more or less and all those fancy buttons and gadgets they put on their boards, I guess in the long run the saying "what shines isn't always gold" is true, they have their share of goof ups just like everyone else, but they have regular updates and fixes for their stuff and very good CS ....compared to HP or Dell
I was also thinking putting another x58 SLI rig together but maybe - like you said - I should wait until those 2011 cpu's come out, I'm the type that likes to build them cover them up, let them sit on top of the desk looking good until I've have had enough of them and then sell them or give them away to family or friends in exchange of beer.
Thanks for all your input I really appreciate it.
