Community
cancel
Showing results for
Search instead for
Did you mean:
tuckchaang
SSD differences unclear
Jump to solution
The Wolfville SSD specs are unclear:
MM#927441: SSDSC1NB800G401 and
MM# 927440: SSDSC1NB800G4IB
Under the comparison table, the difference is the form factor:
https://ark.intel.com/content/www/us/en/ark/compare.html?productIds=75686,75685 However a public link https://www.intel.it/content/dam/technology-provider/public/documents/wee-in-scope-list-february-201... stated the weights for both are same, essentially assuming the form factor is same for both. Would you please confirm and let me know the difference of these 2 products (SSDSC1NB800G4IB, SSDSC1NB800G401)? Thank you.
BrusC_Intel
Hello, @tuckchaang.
Thank you for contacting the Intel Community Support.
I received your ticket regarding the difference between the two models, I will be glad to assist you.
You can disregard the information from the document you found, the information listed in the ARK page regarding the form factor and weight is correct (also a slight difference in Power while in idle/active).
If there is anything else, please let me know.
Bruce C.
A Contingent Worker at Intel
BrusC_Intel
Hello, @tuckchaang.
Bruce C.
BrusC_Intel
Hello, @tuckchaang.
I wanted to follow up on your ticket to check if further assistance is required.
Please let me know if you have any other questions or if we can proceed to close the thread.
Bruce C.
BrusC_Intel
Hello, @tuckchaang.
This message is to follow up on your ticket regarding the product specifications of the S3500 Series.
I previously shared that the information in the ARK page is accurate and can be used to compare both models.
The thread will be closed right now, if you require any type of assistance from Intel in the future or have other questions, please open a new thread as this one will no longer be monitored. You may also use any of the other contact methods (https://www.intel.com/content/www/us/en/support/contact-support.html).
Bruce C.
A contingent Worker at Intel
