Solid State Drives
Support for Issues Related to Intel® Solid State Drives
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
4365 Discussions
SSD for DX58SO motherboard
Community Manager
Can you please suggest if Intel motheroard DX58SO (with i7 920 CPU) support Intel SSD drives?
Thank You
Bhupinder
Community Manager
Any system with a SATA port should work just fine with an SSD. SSDs are not special in that regard; motherboards do not need "special support" to work with an SSD, nor vice-versa. The CPU model you're using also has zero relevancy.
The http://www.intel.com/products/desktop/motherboards/DX58SO/DX58SO-overview.htm DX58SO has six (6) SATA300 ports driven by an Intel ICH10R southbridge, and two (2) eSATA ports driven by a Marvell controller. Technical specifications of the board http://www.intel.com/support/motherboards/desktop/DX58SO/sb/CS-029867.htm are available.
Community Manager
Thanks Koitsu for answering my question.
Bhupinder
