Community
cancel
Showing results for
Search instead for
Did you mean:
RKtos
SSD for NUC 5i5ryh
Hi All,
I want to buy the new intel nuc 5i5ryh. I was lookong for SSD but I feel confused.
I've found 2 disk
  • SSDSCKGW180A4
  • SSDSCKGW180A401
but I am not able to find the difference between them.
Is there any difference?
Which one can I use in the nuc (the first one is cheaper)?
Cheers,
Rafal
ASouz7
Hello rafal2eng,
They both are the same drive as you can confirm here in this link: http://ark.intel.com/products/77949/Intel-SSD-530-Series-180GB-M_2-80mm-SATA-6Gbs-20nm-MLC# @ordering ARK | Intel® SSD 530 Series (180GB, M.2 80mm SATA 6Gb/s, 20nm, MLC) the difference is in the package. Intel does not sell products directly to end users. To get more details on it, please contact one of our resellers. You may want to contact your nearest Intel contact center to find out about your nearest reseller by accessing this link as well: http://www.intel.com/p/en_US/support/contactsupport Contact Support - If you are located in The United States or Canada, you may try this link for a list of distributor: http://cache-www.intel.com/cd/00/00/08/99/89937_89937.pdf http://cache-www.intel.com/cd/00/00/08/99/89937_89937.pdf
RKtos
Hi aleki_intel,
Thank you. Your answer is very helpful. It means that I can buy a cheaper version. To be honest I do not understand why in the same re-seller there is 50$ difference.
So, I am ordering SSDSCKGW180A4.
Cheers,
Rafal
