Community
cancel
Showing results for
Search instead for
Did you mean:
MVeen2
SSD not showing in disk management
Hello all,
This is my first post here, thanks for having me.
I have a bought an ASUS N550JK and now I want to add a 240GB SSD to it (Intel SSDSC2BW240A401). I removed my optical disk and have a HDD Caddy to add my SSD.
After this I didn't see the SSD in my computer, so I started searching and found several things. But it didn't answer my problem.
In the device management the Intel SSD is shown, but in the disk management I cannot find it:
http://puu.sh/asvi2/c21a65cb68.jpg http://puu.sh/asvi2/c21a65cb68.jpg - Device Management
http://puu.sh/asvm3/d981724fb2.jpg http://puu.sh/asvm3/d981724fb2.jpg - Disk Management
I also checked my BIOS and the SSD is shown there. Can someone say what I doing wrong?
Thanks in advanced.
Kind regards,
Menno Veen
PS: Intel Toolbox can also not find the SSD...
jsing21
did you format your SSD before installing?
If no, I suggest back up your data, and format your SSD and reinstall your OS only in SSD.
Not worry, It is totally fine.Your SSD is working but your OS has some Error.
Kevin_M_Intel
Hi MennoVeen,
As jeevan singh said, it is possible the Operating System may have a problem and re installing the Operating System may do the trick. You say Disk management does not show the SSD at all or you do have it there but maybe it is not initialized?
Kevin M
MVeen2
I receive a new SSD tomorrow. If it is not solved, I will try this! Thank you guys!
Kevin_M_Intel
Ok, let me know!
Kevin m
MVeen2
The new one works immediately, so there was a problem with the SSD.
Kevin_M_Intel
I am sorry for the trouble but it is good to know it is working now.
jsing21
do one think format your windows and reinstall windows and your windows is only install on the SSD
and before u reinstall windows first u format your SSD
SSD if OK there are no problem on SSD
Kevin_M_Intel
I am sorry but I not caching your idea. Can you paraphrase it?
GHodg
In Disk Management did you go to the Action menu at the top and select "Rescan Disks"? A lot of ppl miss this step.
