cancel
Showing results for
Search instead for
Did you mean:
SSD not working
Esteemed Contributor III
Hi!
I have a x-25m g2 80 gb 🙂 and i have installed
connected to a vt6421 pci controller with sata ports.
It can be viewed in disk management under win7 ultimate rtm.
But i cannot partition or format it because the system
launch the message formatting not possible or somehing like that.
Why?
I've tried all:
secure erasing.
formatting over a live kubuntu distro
connecting to various sata ports on controller
connected to a nas with capability of support sata
the ssd in not seen under the latest ssd toolbox
What can I do?
Thanks you
7 REPLIES 7
Did you install the drivers for the vt6421 pci controller?
The exact error message could be helpful.
Yes because win7 have the latest drivers .The ssd is recognized as intel ss scsi diskdevice thanks
Roger on the drives.
Maybe I'd have an idea if you can reproduce the exact error.
The errore message is formattazione non riuscita.trad:not possible to format.In other session when try to do rapid format the message is impossible to complete format process .????thanks
