Solid State Drives
Support for Issues Related to Intel® Solid State Drives
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
SSD not working
Community Manager
Hi!
I have a x-25m g2 80 gb :-) and i have installed
connected to a vt6421 pci controller with sata ports.
It can be viewed in disk management under win7 ultimate rtm.
But i cannot partition or format it because the system
launch the message formatting not possible or somehing like that.
Why?
I've tried all:
secure erasing.
formatting over a live kubuntu distro
connecting to various sata ports on controller
connected to a nas with capability of support sata
the ssd in not seen under the latest ssd toolbox
What can I do?
Thanks you
Community Manager
Did you install the drivers for the vt6421 pci controller?
The exact error message could be helpful.
Community Manager
Yes because win7 have the latest drivers .The ssd is recognized as intel ss scsi diskdevice thanks
Community Manager
Roger on the drives.
Maybe I'd have an idea if you can reproduce the exact error.
Community Manager
The errore message is formattazione non riuscita.trad:not possible to format.In other session when try to do rapid format the message is impossible to complete format process .????thanks
Community Manager
I ll try to use parted magic cause probably in security freeze lock.
Then try to Connecticut to an ide_sata adapter for set it as boot drive.
I want test it sito os w7
Community Manager
Hi!
I've booted with parted magic and do a secure erase.
the ssd is not in frozen state.
But with win7 i cannot format it.
I'll try to connect to a ide port with an adapter and format in this conditions.
Thank you
Community Manager
don't run!
for me it's dead
answers????
