Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
SSD on win 7 works periodically
Hi there.
I own an SSD (80gb) and since the last 3 days, I am trying to clone my hard disc.
I use Acronis for back up. I also try Paragon for back up.
When I used Acronis to clone my hard disc with the OS (win 7), I check the box with the NT Signature. After the copy, I unplug the old hard disc... and leave the SSD. That was! It worked!
I shut down the computer... Switch it on again... and it stucks on "windows loading".
I try everything. I also try to instal windows 7 from the beginning.
After the installation finishes... it worked.
I did a restart and then stucks again.
I select system repair. It repairs the problem.
Then It starts again normaly.
After some hour, I decide to restart my PC.
Again the same problem.
Now I decide to use my SSD with the laptop. If I face the same problem, I am afraid that I have to ask for a replace.
MBall5
New Contributor II
Hello I would like to let you know that the regular tools for back up or mirroring does not apply for Solid state drives, I would like to recommend the following tool from Intel: Intel® Data Migration Software, The Intel® Data Migration Software copies your drive's contents from your old storage device to your new Intel® Solid-State Drive. The software can help make this transition smooth and painless. you can find this tool at the following link: http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=19324&lang=eng http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=19324&lang=eng
I hope this helps with this issue.
Also I would like to let you know that if the solid state drive is not responding we recommend performing a secure erase, if the issue persists please contact the solid state drive support at the following phone number: 916 377 7000 option 6.
