cancel
Showing results for
Search instead for
Did you mean:
SSD restart problem on Win7
Esteemed Contributor III
Since installing the new firmware on my 80gb G2 drive, the computer will not start windows properly if I do a Restart. Doing a full power down shutdown and then starting works fine every time.
It hangs at the Starting Windows message and never progresses.
Any thoughts??
3 REPLIES 3
Can you please specify your system specs.
EVGA 680i Motherboard using built in SATA.
6gb Ram. INTEL 6600 CPU.
Not sure what else you'd want.
Tom
I think someone posted problems with the same mobo.
