Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
SSDPE2MW400G4R5 vs SSDPE2MW400G4X1
Hi All
I'm planning a new system build and am wanting to use one of the new 14nm Broadwell-E asus mobo's, the x99-a II
I see it has one u.2 and one m.2 connection.
I know the SSDPE2MW400G4R5 says 'requires SFF-8643 Connector on Motherboard' (U.2) and includes the cable.
Does this mean the SSDPE2MW400G4R5 can connect to both U.2 and M.2 slots on the mobo? And that the SSDPE2MW400G4X1 can only connect to the M.2 slot?
I am a little confused between the two and any clarification on the pros/cons of each would be appreciated.
Tags (1)
Community Manager
Gast,
As we understand you would like to know about the difference between those two Intel® SSD 750 Series 400GB.
Checking the model numbers you provided, the drive is the same, the U.2 version of the SSD.
Actually we only have two versions of the Intel® SSD 750 Series, please check this http://ark.intel.com/compare/86742,86740 link. One is the U.2 and the other one is the AIC (Add In Card) HHHL (Half Height Half Lenght).
There is not M.2 version of this drive, we suggest to verify this http://www.intel.com/content/www/us/en/support/solid-state-drives/consumer-ssds/000005797.html link before you decide to buy the SSD.
If you have any other question please let us know.
NC
Community Manager
Gast,
We are following up in this thread and we would like to know if you have any other question about it or if the answer provided was correct for you?
We will be waiting for your response.
NC
