Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
SSDSA2CW600G310 Data erased in running mode
Did anybody else experience the same problem:
I have now my second SSDSA2CW600G310 in my Win 7/64 Bit system and the data was repeatedly erased in running mode (without system shut-down
or power loss).
I have installed the latest 320 Series Firmware.Update, but the result is the same.
candyandy
MBall5
New Contributor II
On this specific case I suggest you to run the Intel ssd optimizer, under the Intel SSD Management Tools from the Intel SSD toolbox, you can find that tool at the following link:http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18455&lang=eng&wapkw=solid%20state%20... http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18455&lang=eng&wapkw=solid%20state%20...
If the issue persist I suggest you to contact the system manufacturer for further assistance.
Community Manager
I found the issue in between.
It was my motherboard. I guess an issue with the S/ATA-ports, since the issue occured also with a standard HDD drive.
After exchanging the motherboard everything runs seamlessly now.
Rgds,
candyandy
