cancel
Showing results for
Search instead for
Did you mean:
SSDSA2M080G2GN bad benchmarks
Esteemed Contributor III
I am getting sequential writes in the 30MB/s and reads in the 40MB/s range using AS SSD benchmark.
Firmware is 2CV102HD.
Could the drive encryption be the reason for this (PGP full encryption)?
Thanks a lot!
20 REPLIES 20
ambizytl, here is the screenshot ....
Do you see something suspicious (except that the results are bad)?
What are the results you'd expect?
Thanks a lot again!
Why did you block out the firmware information and driver, etc.? Everyone posts the complete picture and there is nothing to worry about. I wanted to see what driver, firmware, and whatever else shows, so post again with complete picture, and don't worry! There is nothing in that blacked-out area that anyone could make use of.
Yes, the results are bad, but post it again without the blacked-out area. I will show you one of my test results using the 80GB drive, and I have two others that are both 160GB.
By the way, I noticed your drive doesn't state ATA device as mine does. How is your drive displayed in Device Manager? ATA...SCSI...?
Here you go ... I did not know what some of the numbers mean, so I just blocked it out before.
Thanks!
Not really sure how to answer your last question. It shows in device manager just under "Disk drives", it does not say ATA, SCSI or anything. Where exactly would I look for that?
