Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
SSDSA2M080G2GN bad benchmarks
I am getting sequential writes in the 30MB/s and reads in the 40MB/s range using AS SSD benchmark.
Firmware is 2CV102HD.
Could the drive encryption be the reason for this (PGP full encryption)?
Thanks a lot!
Tags (1)
Community Manager
Yes, encryption would likely be the reason. There is an issue with SSD Toolbox and encryption, just as with RAID. I assume you are not using the msahci driver for AHCI and need to run Optimizer for TRIM. The following is from SSD Toolbox Read Me:
<!-- /* Font Definitions */ @font-face {font-family:Wingdings; panose-1:5 0 0 0 0 0 0 0 0 0; mso-font-charset:2; mso-generic-font-family:auto; mso-font-pitch:variable; mso-font-signature:0 268435456 0 0 -2147483648 0;} @font-face {font-family:"Cambria Math"; panose-1:2 4 5 3 5 4 6 3 2 4; mso-font-charset:0; mso-generic-font-family:roman; mso-font-pitch:variable; mso-font-signature:-1610611985 1107304683 0 0 415 0;} @font-face {font-family:Calibri; panose-1:2 15 5 2 2 2 4 3 2 4; mso-font-charset:0; mso-generic-font-family:swiss; mso-font-pitch:variable; mso-font-signature:-520092929 1073786111 9 0 415 0;} @font-face {font-family:"Neo Sans Intel"; panose-1:0 0 0 0 0 0 0 0 0 0; mso-font-alt:"Segoe Script"; mso-font-charset:0; mso-generic-font-family:swiss; mso-font-format:other; mso-font-pitch:variable; mso-font-signature:3 0 0 0 1 0;} /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-unhide:no; mso-style-qformat:yes; mso-style-parent:""; margin-top:0in; margin-right:0in; margin-bottom:10.0pt; margin-left:0in; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;} .MsoChpDefault {mso-style-type:export-only; mso-default-props:yes; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;} .MsoPapDefault {mso-style-type:export-only; margin-bottom:10.0pt; line-height:115%;} @page Section1 {size:8.5in 11.0in; margin:1.0in 1.0in 1.0in 1.0in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.Section1 {page:Section1;} /* List Definitions */ @list l0 {mso-list-id:1018461300; mso-list-type:hybrid; mso-list-template-ids:-820628554 -60786850 67698691 67698693 67698689 67698691 67698693 67698689 67698691 67698693;} @list l0:level1 {mso-level-start-at:0; mso-level-number-format:bullet; mso-level-text:; mso-level-tab-stop:none; mso-level-number-position:left; margin-left:67.5pt; text-indent:-.25in; font-family:Symbol; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast;} ol {margin-bottom:0in;} ul {margin-bottom:0in;} -->
The Intelâ SSD Toolbox cannot detect the difference between a drive in a RAID configuration and a drive that is using encryption.
· When the Intel Optimizer function is set to run on a drive that has been encrypted, the SSD Toolbox software cannot determine if the drive is in RAID mode or if the drive is using encryption technology
Community Manager
I can't find it now, but I would expect same issue with encryption using msahci driver is possible.
Community Manager
Are you using Windows 7?
I found some more information about the Optimizer that conflicts somewhat with the other information I posted above. This is from the SSD Toolbox Optimizer White Paper:
Q2 Will the Intel® SSD Optimizer work with my drive encryption software?
A2 Yes, the Intel® SSD Toolbox will work with encryption software. On Windows Vista* or Windows 7, a prompt will appear within the Intel® SSD Toolbox allowing the user to force the Intel® SSD Optimizer to execute if the user can verify that their Intel SSD is not part of a RAID array. Clicking "accept" will optimize the drive successfully. On Microsoft Windows* XP, it will work with no additional user input required.
http://download.intel.com/support/ssdc/hpssd/sb/intel_ssd_optimizer_white_paper_rev_2.pdf http://download.intel.com/support/ssdc/hpssd/sb/intel_ssd_optimizer_white_paper_rev_2.pdf
Community Manager
Thanks ambizytl!
Yes, I am running Win7 64 bit. I did get the raid / encryption warning when using the optimizer from within the toolbox, clicked ok and it did the optimization fine. It did not improve the performance, though.
In the Windows experience index, I get a score of 5.8. Pretty embarassing.
Just to confirm: my SSDSA2M080G2GN is a Gen 2 drive, correct?
Is there anyting that can be done to improve the performance?
Thanks again, guys!
Community Manager
Yes, that would be a G2 drive.
Seems like TRIM may not have run. Do you have Disk Defragmenter disabled or turned off for the SSD? I assume you are not doing RAID. Are you running in AHCI mode? What port is the SSD in? What SATA AHCI controller and driver do you have?
Just so you know, I will be back in a few hours.
Community Manager
ambizytl,
the optimizer said that it had finished.
This is a laptop that I just got yesterday. The automatic defrag was enabled to run once a week when I got it, but I disabled it right away.
SATA is configured as AHCI. I can see an "Intel ICH9M-E/M SATA AHCI controller" in device manager, driver version 8.9.0.1023, provided by Intel.
No RAID.
Thanks for your help!
Community Manager
Have you run the optimizer? Try running it again. Do you have the optimizer setup to run on a schedule or are you going to do it manually?
Community Manager
I just re-ran optimizer, it turned green and showed the status as "passed". No performance change. Really, I would not have expected any, as the system was built yesterday.
I am planning on running the optimizer manually.
Starting to think that the performance hit comes from the encryption. It's a very very bad hit though, much more than I would have ever expected. Bummer. :-(
Community Manager
Please post a screenshot of your AS SSD benchmark results. Save the screenshot and upload here in your message. It could be the encryption but maybe something will show up in that screenshot.
Community Manager
ambizytl, here is the screenshot ....
Do you see something suspicious (except that the results are bad)?
What are the results you'd expect?
Thanks a lot again!
Community Manager
Why did you block out the firmware information and driver, etc.? Everyone posts the complete picture and there is nothing to worry about. I wanted to see what driver, firmware, and whatever else shows, so post again with complete picture, and don't worry! There is nothing in that blacked-out area that anyone could make use of.
Yes, the results are bad, but post it again without the blacked-out area. I will show you one of my test results using the 80GB drive, and I have two others that are both 160GB.
Community Manager
By the way, I noticed your drive doesn't state ATA device as mine does. How is your drive displayed in Device Manager? ATA...SCSI...?
Community Manager
Here you go ... I did not know what some of the numbers mean, so I just blocked it out before.
Thanks!
Community Manager
Not really sure how to answer your last question. It shows in device manager just under "Disk drives", it does not say ATA, SCSI or anything. Where exactly would I look for that?
Community Manager
Well, I would suggest installing Windows 7 with BIOS set to AHCI and use default msahci driver, which runs TRIM automatically without SSD Toolbox. You will also get Standard AHCI 1.0 Serial ATA Controller on your system by doing the install.
At this point, I don't know if encryption is the issue or your driver and BIOS mode. The other thing is I don't see ATA Device listed after your drive, as you see in my picture. Does Device Manager list your drive as an ATA Device?
Community Manager
In Device Manager click on Disk drives to expand the list and tell me what it says or post a picture. I don't think you have the right setup--something is wrong if you don't see ATA Device listed on same line as your SSD.
Community Manager
ambizytl, this is what it says in device manager (see below).
Unfortunately, OS re-installation is not an option at this point. Unless I know 100% for sure what the issue is, how to fix it and I can back it up.
Please let me know what you think about the screen shot. Not sure what it's supposed to say there.
Community Manager
After the model number on same line in my system with Windows 7 it says ATA Device. It could be encryption is your problem, as you alluded to earlier, but first let's try something else:
I suggest switching to msahci driver to see if that helps: Go to Device Manager>IDE ATA ATAPI controllers>right-click the ATA Channel with your SSD>click Update Driver Software>Browse Computer for Drivers and choose Microsoft Standard AHCI driver from the list.
Community Manager
It lists "IDE Channel" instead of "ATA Channel 0". hmmm .... Any idea?
Community Manager
What port is your SSD in?
Why do you say IDE Channel is listed instead of ATA Channel 0? Not all motherboards have a port 0. Do you have a port 0 on your motherboard? If you do, what is in it?
