Community
cancel
Showing results for
Search instead for
Did you mean:
FLond
SSDSC2BA800G4 800GB SATA 6Gb/s
Which command will get the SSDSC2BA800G4 SSDs to a fresh out of the box (FOB) state?
Community Manager
Hello Franc,
The best way to return your https://ark.intel.com/products/84239/Intel-SSD-DC-S3710-Series-800GB-2_5in-SATA-6Gbs-20nm-MLC Intel® SSD DC S3710 Series to a FOB state will be by performing a secure erase (aka low-level format). This will effectively and permanently remove any data that you may have placed on the drive.
Please keep in mind that this will not remove any encryption or drive password protection, nor will it un-do any firmware updates you may have performed.
There are several ways to perform this action:
  1. Using the https://downloadcenter.intel.com/download/26575/Intel-SSD-Data-Center-Tool Intel® SSD Data Center Tool:
    1. isdct.exe delete -intelssd (Index|SerialNumber) (example: isdct delete -intelssd 1). For SATA devices, this will issue an ATA Secure Erase command.
    2. http://www.intel.com/content/dam/support/us/en/documents/solid-state-drives/ssd-software/Intel_SSD_D... Intel SSD Data Center Tool User Guide (Page 41 for syntax. You will find examples on pages 42 and 43).
  2. http://www.intel.com/content/www/us/en/support/memory-and-storage/000022179.html Secure Erase with Microsoft DiskPart*.
  3. http://www.intel.com/content/www/us/en/support/memory-and-storage/000006198.html Run a Low-Level Format on Intel® Solid State Drives (using bootable third-party tools).
We hope this information helps.
Carlos A.
Community Manager
Hello Franc,
We hope the information provided was enough to answer your question.
If you still have more question, or any more issues, feel free to contact us again.
Carlos A.
