Community
cancel
Showing results for
Search instead for
Did you mean:
MN5
SSDSC2BB012T401
SSDSC2BB012T401 - It is ok for my macbook pro retina 15" (mid 2012)?
jbenavides
Hello MaxMustache,
Welcome to Intel Support Community. We would like to thank you for your confidence in Intel products.
Regarding your inquiry, Intel® SSD's are manufactured to meet or exceed current IT standards, however, some PC manufacturers may add customizations or restrictions to their systems that will limit the types of Hard Drives that can be used with them.
The best source to determine the compatibility of Intel® Solid-State Drives with your computer is the manufacturer of the system. We advise you to contact http://www.apple.com/support/ Apple Support so they can let you know if your computer is able to use this Intel® Solid-State Hard Drive.
Here is some additional information about the SSD, so you can compare to the requirements of your Macbook:
Intel® SSD DC S3500 Series 1.2TB
Model number: SSDSC2BB012T401
Interface: SATA 3.0 6Gb/S
Form Factor: 2.5" 7mm
You can find additional specifications in the following website:
http://ark.intel.com/products/82118/Intel-SSD-DC-S3500-Series-1_2TB-2_5in-SATA-6Gbs-20nm-MLC# @specifications http://ark.intel.com/products/82118/Intel-SSD-DC-S3500-Series-1_2TB-2_5in-SATA-6Gbs-20nm-MLC# @specifications
